A/C pully needs to be changed, 98 4.6
Old Jul 5, 2006 | 10:55 AM
Dip_krew's Avatar
how indepth is this job? my 98 4.6 needs a new clutch assembly for the a/c and im not sure how much work will be needed to change it if i choose to do it myself.
is it just a few bolts? can anyone post a breakdown of it?
thanks!
Old Jul 5, 2006 | 02:19 PM
Dip_krew's Avatar
anyone?
Old Jul 5, 2006 | 03:40 PM
chester8420's Avatar
Originally Posted by Dip_krew
anyone?
I've never done it. Just take it apart and find out!
Then you can write a review....
Old Jul 5, 2006 | 05:28 PM
JMC's Avatar
JMC
25 Year Member
I would invest in a manual. It does require the removal of the Compressor. A puller and holding tool are also required. There should also be a snap ring that has to be removed.
JMC
Old Jul 5, 2006 | 11:18 PM
Dip_krew's Avatar
its not my truck, my neibough asked me if i could fix it for him and before i got in over my head, i wanted to make sure i knew what i was getting into
Old Jul 6, 2006 | 03:13 AM
pjb999@yahoo.co's Avatar
It sounds to me like it could be a lot of work, if you have to remove the compressor, you'll have to drain the refrigerant, and laypeople aren't supposed to as you're supposed to recover the stuff, not to mention you don't want contaminants in there.
To cap it off, if you screw up, it's not your vehicle you're messing with, so I'd pass on it, personally
Old Jul 6, 2006 | 07:14 AM
Ted'98's Avatar
I removed my old pulley and installed a new one with the compressor still bolted in place. It wasn't the easiest thing to do because of how tight things are, but it is do-able.
Since it is your neighbors truck, I would recommend not touching it. Since you are dealing with the A/C, that project could go bad quickly.
Old Jul 6, 2006 | 09:43 AM
Dip_krew's Avatar
yeah, ill heed the advice and pass it on, im sort of the neibourhood mechanic, people tend to drop vehicles 2-3 times a week off for repair at my house, and it gives me a few hundred bucks exta in my pocket.
but ive never touched a/c before. and i dont think ill pop my cherry on this one either.
thanks for the advice guys
