Help---plese!!!!
Help---plese!!!!
I went to start my truck the other day and it wouldnt fire up.2001 5.4. about 89000 miles. Checked Air(Replaced MAF and Filter and ran meter)--good ----Fuel--to the rail/good ---Spark--pulled the plugs and replaced. New Battery,New Filter. New Fuel Relay, Checked all fuses and connections and metered. Checked with OBD II and got no codes. It turns over fine, just wont fire. ANY IDEAS!!!
Originally Posted by Faster150
check the crank sensor and cam sensor... those will go bad and cause this problem.
I went out today and double checked the fuel pump with a meter and the voltqge was within specs. Pulled the gas rail to the injectors andhad gas there at point. Checked the fuel cutoff and it was fine. Dazed and confusd now( not that really hard for me considering)
