fuel filter
Old Jul 4, 2006 | 01:13 PM
Green Ford's Avatar
fuel filter
I recently tried to change the fuel filter on my 04 f150, but no luck can anyone tell me how to do it . Or do i need some kind of special tool
Old Jul 4, 2006 | 01:27 PM
jbrew's Avatar
Search this forum for the answere. This topic has been covered many times...
Thanx and welcome ..
Old Jul 4, 2006 | 01:30 PM
twobutte's Avatar
fuel filter
Go to your local NAPA and buy a fuel filter coupler release kit, these are a series of plastic collars that wrap around a specific diameter fuel line, you push the thin end into the coupler and it relieves a spring so you can pull the fitting apart, caution it can be very hard if its old or in a high humidity environment. Also BEFORE proceeding disconnect the battery and relieve all pressure from the fuel rail, you will find a "tire inflator"type connection on the rail, just take a rag and a screwdriver, make sure hte engine is cool,
Old Jul 4, 2006 | 02:07 PM
Green Ford's Avatar
fuel filter
I did look in the forum but no luck
Old Jul 4, 2006 | 02:12 PM
Green Ford's Avatar
fuel filter
Thanks but i understand about the plastic clips .My problem is that i can,t get the filter off the the line that comes from the engine.
Old Jul 4, 2006 | 02:32 PM
jbrew's Avatar
Really ? You can't find anything ?? Well here's the tool that finally worked for me when I had issues with this. The trick is , First release the spring with the tool - pull the line towards the filter then back from the filter. The first time you have to muscle it a bit , but it works ..
F150.net also may have articles on this, that may be were I seen them..
https://www.f150online.com/galleries...051&anum=10943
Old Jul 4, 2006 | 10:19 PM
matcount63's Avatar
fuel filter
i had the same problem i coulndt get the line of so what i did i cut the fuel line off at the retainer put in a neopreme line in high pressure with speacial clamps now when i change the filter all i need to do is loosen the clamps no more special tools a 2ft piece of line with clamps is 16.00 bucks
Old Jul 4, 2006 | 11:13 PM
jbrew's Avatar
LOL -Funny , I thought about doing something like that until I finally got the %$$@@#$^$^ thing apart... Once you get apart the first time it's easier the second. But , that idea sounds good too..
