View Full Version : HVAC
Pages :
1
2
3
4
5
6
7
8]
9
10
11
- AC compressor wiring color code?
- A/C Blows Cold....Then Hot?????
- a/c stopps blowing through vents
- Foul odor coming from AC
- AC goes warm when moving
- 95 XLT power window motor
- A/C blows only hot air, 134a is recharged
- Blower motor or something else?
- Insufficient Cooling
- How do you know when to recharge the system?
- Replacing compressor...what else needs to go
- Rear A/C rattle?
- 99 expedition psi
- 94 f-150 A/C question
- A/C question
- Vaccuum leak
- A/C not functioning properly
- HVAC problems
- What are the signs the compressor is going ??
- Replaced condensor coil, what next b4 charge?
- change to digital ac?
- 2006 Lariat Crew 5.4 A/C problems
- AC blows but air isn't cold after a charge.
- Swapping in electronic A/C controls??
- Blend Door Problem
- Bad Heater Core
- Think you have all the f-150 answers? Take a stab at this one.
- A/C Kicking On and Off
- Same old vacuum problem
- '90 F-150 A/C Resurrection
- Death Kit
- A/C blows cold but weak air preasure
- Yet another A/C question......
- HVAC vacuum line through firewall
- Won't take charge after vacuuming
- A/C compressor cycling question
- Leave the AC on or turn it off every time?
- How much oil?
- A/C always on?
- Dodge Dakota compressor damage
- AC blows through defrost vents
- 97 ford Expedition what pressure?
- Noise when AC turns on
- A/C Won't charge?
- needing to charge my ac
- Where can I find HVAC maintenance service??
- AC Chatter
- Position of can when charging
- A/C warm in city, cold on highway?
- A/C issues
- A/C issues
- 100psi on low side - Compressor won't kick in
- Ford HVAC controls STILL suck
- Ran into an A/C problem that everyone might want to check for in their vehicles.
- AC through defrost (different problem) not vacuum
- A/C slow to cool, compressor noisy
- Need new Compressor
- Ac Goes From Cold To Hot "female In Florida Needs Help"
- Vacuum
- Just added 17 Oz. R-134a still 36PSI
- A/C fan.......
- 2001 F150 AC cycles cold to hot over and over
- AC Service Port Low side Expedition 1999
- A/C problems self diagnosed (I think)
- 03 Expi Rear A/C not working
- Another odd AC issue
- A/C stoped working????//
- HVAC switches from panel to defrost and floor
- HVAC Console Lighting
- Cabin air filters, what's that about?
- HVAC has weird smell
- HELP, my A/C just stoped working
- ac also thru heater, need motor id & action..
- A/C Issue... WIERD...
- Possible A/C clutch problem please help!!
- A/C blowing hot and cold air - F150 SC
- A/C Blowing Hot Air, Even On Cold
- Loud Noise when A/C turned on
- HVAC and mpg
- Zero pressure
- A/C blows through top defrost.
- What is up with my AIR!!
- HVAC Help!
- Vent just under climate contols
- AC in Split vent selection et al?
- Werid One
- Climate control unit replaced
- A/C has good preassure reading
- Air stays on after ignition is off!!
- Floor vent y pipe. DELETE?
- wierd A/C problem
- F150 2001, Blend door problems
- A/C only works on Low, High switch blows same as low
- blend door or switch or what?
- I think I only need an a/c clutch...
- Running water?
- Anyone have the Infamous Heater Core Instructions?
- Air squeal from vents.
- cap for service port
- Now I am not sure
- A/c not working even with a new compressor
- Standard Climate to Auto Climate control conversion
- need help with blend door
- AC fan?
- A/C blowing like heater
- Blend door Instructions (Expy)
- Defrost/Floor Noise
- A/C staying on...?
- AC/defrost also blows thru heater vent...
- A/c Recirculate Button
- Heater Core???
- Air velocity out of vents seems slow
- Ac Condenser J-b Weld
- Fan stopped blowing?
- 134a question Having some problems
- Blend Door Replacement Pictures
- A/C on
- 2002 lariat cliamate control issue
- Heater Control
- replaced heater core, have problem, need help
- Electric heater
- Vacuum loss fix?
- 03' screw heater problems
- Tricks to getting at the orifice?
- Heat is stuck on!
- Air Con flow-return lines
- Heater Inlet Hose Replacement - Help!!!
- installing AC in a 2006 f150
- 2000 expy blower runs with key off
- 134a
- OE lower radiator hose remove how?
- Manual HVAC to Auto HVAC
- Heat issues in 2 trucks
- Temperature Control not working on HVAC System
- Any Thoughts? Noise from Vent
- Air Flowing at 60MPH, why?
- Heater core/Water pump/radiator
- very little heat....brrrrrrrr
- How does this work?
- Please Please Help!!!!!!!!!!!!!!!!!!!!!!!!
- Coolant leak pass. side bottom of rad.
- I have an idea but will it work?
- Is my A/C Comp running?
- engine running hot, or Temp. Gauge spike
- No Control over Temperature
- heater core
- Low heat/engine running cool
- Charging Heat?
- DESPERATE for detailed instructions on heater core replacement PLEASE HELP!
- 1992/302 belt question
- random heat
- What is the part # for the blend door motor
- Where do the HVAC vacuum lines go to?
- 1999 f150 xlt no heat
- weak blower output?
- Heat Question
- Blend door replacement with pictures
- AC/Heat question!A way to test the Blend Control Switch?
- Heat on my work van doesn't work well
- I replaced my blend door and heater core. Happy ending!
- Vacuum diaphram info. Please help
- ac/heater fan resister
- Heater core/blend door replacement questions
- A/C on all the time
- Random Heater Operation
- No Floor Heat Or A/c
- 98 F-150 heater problem
- 98 F-150 little or no heat
- exhaust fumes
- Rear A/c
- A/C cycling on and off - couple questions
- Heater core advice
- Repaired my blend door control motor 2000 f-150
- Blend Door
- 02 Harley A/c problem
- Auto Climate Conversion
- EATC - Only through defrosters??
- 89 with A/C problem
- Replacing HVAC Blower Resistor on 2001 F-150
- Heating coil
- Automatic Climate Control
- New compressor louder than original. Normal?
- Bad Bearings...
- HVAC question
- Thumping noise from HVAC
- 97' f150 HEATER CORE REPL/DASH REMOVAL
- hissing sound comming from control panel
- A/C Hissing sound
- Rats or mice...it's one of them
- bad compressor?
- Bad compressor?
- Gauges
- EATC display problem
- When does the AC compressor cycle?
- Problems with a/c blower motor- ideas????
- AC losing freon
- Where to check/charge A/C? 4.6 liter
- A/C only blows thru the defrost vents. 98 F150
- Flame Grilles - Effect on A/C and Engine Temp
- Weird sound only when using A/C????
- 1997 Expy-5.4-A/C stops blowing with acceleration???
- Hvac
- Rear Air Conditioner
- EATC not working
- Blower doesn't work
- Restriction in system?
- Is a compressor hard to replace?
- Retrofit Blues
- A/C Help: Clutch or Compressor?
- Change Standard AC Contols To Automatic
- Missing service port cap. please advise
- A/C Upgrade
- Do I need a recharge?
- 2001 SCrew needs A/C Recharge - something I can do??
- Orifice Tube Location / Compressor Question
- A/C noise...
- Cabin Filter...Location?
- A/C question
- A/C Compressor Blues
- R12 to R134a -- How to do it??
- brand new Screw, blowing warm :(
- Buying A/C parts online?
- 1993 F-150 5.0, what A/C system?
- 05 F-150 A/C click noise
- AC system diagram
- Automatic climate control - leave on or turn off?
- Need AC help for 2000 F150
- Help with A/C compressor
- Cycling switch question
- HELP!!!!! AC Problems -on vacation
- Supercrew HVAC vacuum line lose in firewall
- Cabin Air Filter
- Bad Evaporator '01 F-150
- AC clutch replacement diagrams
- A/C Shuts off at WOT doesn't come back on
- Need Help. Engine miss/hesitation with A/C on?
- 70psi on Low side?
- high side ?
- F250 KR not cold at idle
- 93 F150 blows thru defroster
- A/C vent temp ?????
- Loose vacuum?
- water in passenger floor
- Compressor Running Constantly
- HVAC Fan Control Failing (Burning Smell)
- Heater Core - Help
- low side ac pressure is high
- A\C Warm under Heavey Acceleration
