ac also thru heater, need motor id & action..
Old May 10, 2006 | 10:05 AM
babyhauler's Avatar
On an earlier post, I told of my ac also blowing/leaking cold air thru the floor vent(apprx 15% of full heat mode). Thus a very cold right foot on a short drive.
I crawled around under there & checked the vac motors & lines. All appear to be operating properly. I did not hear any leaks. The motor up top goes thru all the motions for ea. setting. The lower motor opens & closes the bottom door ok & on command. These are both on the drivers side. I pulled the lower one out & the door opens & closes fine manually. I could not feel any thing (pencil, pens) blocking the door. With the motor out, the hook moved in & out w/ plenty of force to work the door.
Any other ideas or things to check?
Old May 15, 2006 | 10:41 PM
babyhauler's Avatar
Is the dash going to have to come all the way apart to check, repair, replace all the actuators or motors in there? The 2 on the left seem to be working.
Any other ideas or hints?
