93 F150 blows thru defroster
Old Jul 10, 2005 | 02:13 AM
HappyChappy's Avatar
Registered User
I am running my a/c in normal or max air and it works fine. Then suddenly out of nowhere it kick over to the defroster for about a 1 min then kick back over to the vent. It never starts out this way it always happens after I ran for a bit wit h the a/c on. I saw the other post about a possible vacum leak, but if that the case then why does it switch back and forth.
On a other subject the air is not as cold as it use to be does this mean I need to recharge it? If so how much shoud I put in?
Old Jul 10, 2005 | 10:21 PM
projectSHO89's Avatar
You have a vacuum leak that supplies the vacuum motors. It may be intermittent.
A set of manifold guages is needed to perform an accurate diagosis of the A/C system.
Steve
Old Jul 17, 2005 | 07:24 PM
Registered User
Would this be under the hood or in the cab or both?
