A/C blows only hot air, 134a is recharged
Old Jul 17, 2006 | 02:57 PM
reidanchristine's Avatar
2000 Ford F-150. When I attempted to use the A/C this summer, all that came from the vents was a steady stream of hot air. I checked and recharged the 134a, even though it seemed at acceptable levels. I have checked, I think, all of the fuses, too. I am unsure on what the issue is. Can anyone help out?
Old Jul 17, 2006 | 03:50 PM
beckerjs's Avatar
is the a/c working? sweat beads on the lines? blend door stuck?
Old Jul 17, 2006 | 04:12 PM
gobra's Avatar
is the clutch on the compressor engaging? turning with the belt? Sometimes they get stuck, use some pbblaster on it
Old Jul 17, 2006 | 05:15 PM
blend door stuck?
What is the EASIEST way to tell if the blend door is stuck?
Old Jul 18, 2006 | 01:08 AM
BLUE20004X4's Avatar
Blendor is common in these so lean heavily on it bieng kaput. Some can tell by hearing flapping, but when mine went, tested the controls (fine) then because it let in no cool air at all, like stuck in hot, figured as much as the dealer reported.
Old Jul 18, 2006 | 09:39 PM
KDOTengineer's Avatar
Pull of the blend **** to make sure that the is actually turned to the cold side. These ***** are notorious for cracking on the back and slipping.
It's around $5 for the **** at the dealer.
Old Jul 19, 2006 | 09:50 AM
zziggy's Avatar
the blend air door,, its the door after the AC evaporator and before the heater core that allows full cold, full hot and anywhere in between to mix and then exit the vents.
The blend air door is servo controlled.
The door and motor are probably fine.
The electrical rheostat in the control head is probably bad.
Easy to replace.
Old Jul 19, 2006 | 01:59 PM
Bsallee's Avatar
I think I am having the blend door problem on my 92 F-150. Anyone know where there I can find some type of schematics or instructions on replacing the door? I would just like to know what I am doing before doing it. Any help will be appreciated.
Thanks,
Bernie
Old Jul 20, 2006 | 08:12 AM
I hoped you were correct, but the **** is fine.
After messing some more, it seems that the unit varies the temperature a bit. When I turn the AC to hot, it is extremely hot, yet when I turn the AC to cool it is warm at best.
