HELP, my A/C just stoped working
Old May 10, 2006 | 12:57 PM
ROLLINGon38'S's Avatar
i have a 97 f150. and yesterday i was driving around a parking lot, ( i had my A/C on) But i hit a hole in the street, and my A/c shut off and does not blow any air on any of the settings....is it just something came lose or what?
thanks for any help you cn give me....
Old May 10, 2006 | 08:05 PM
Quintin's Avatar
I'd start by checking the connections at the blower motor, resistor, and blower switch. Check fuse 23 in the power distribution box under the hood, and fuse 23 in the central junction box in the cab.
Old May 10, 2006 | 11:41 PM
where can i find the connections at the blower motor and the other ones you said? i have never done anything with my A/C...i will check the fuses...Thanks
Old May 19, 2006 | 05:06 PM
well i cheacked all the fuses,, and all the connetions that i could see....so where can i find the blower and what els should i look for ....thanks
Old May 19, 2006 | 10:09 PM
Quintin's Avatar
The blower motor and resistor are under the passenger's side of the dash. Poke your head up behind the glovebox, can't miss it.
Old May 22, 2006 | 12:22 PM
well i cheacked every connection i could see and none of them where loose or anything....so is there any where els i should look?
