I think I only need an a/c clutch...
Old Apr 1, 2006 | 06:30 PM
Justinking's Avatar
OK,
Motor on, no AC = everything runs great
Motor on, MAX AC = slight surging, ac pulley will slip an inch for a few secs(smell of burning rubber emitted)(belt slippage i think), and then finally spin out for a couple seconds... no smoke
Just wanted to verify that this sounds like the A/C clutch and not anything else.
Also, is it unanimous that I should buy the clutch from FORD rather than a chain?
Thanks Everyone,
Justin
Semper FI
Old Apr 2, 2006 | 08:27 PM
ltb52's Avatar
Same Problem Almost
I have the same problem almost. I engage the AC at Max AC and all I get is regualr air. Not cooled. I watch the RPM's and I do see a slight dip as the AC is engaged. I had by old man engage the AC while watching and could not see the cluth spinning. Should it spin or should it be stationary? I did a pressure test today and the refrigerant is full. How can I disinguish between a faulty Compressor or clutch?
Old Sep 14, 2011 | 04:17 PM
dbdragracing's Avatar
Just curious what your problem ended up being? My Expo is doing the exact same thing. Thanks.
