Possible A/C clutch problem please help!!
Old May 9, 2006 | 06:14 PM
Blue 4X4's Avatar
Question Possible A/C clutch problem please help!!
I have a 98 F150 that started to act up near the end of last year. It would blow cold then hot, back and forth for no set times. So I did a little reading here and decided I needed to charge the system. Well needless to say I left it until now, but now the compressor wouldn't kick in so I tapped the front while running with a piece of wood and it kicked on. It still wasn't cold so I proceeded to charge the system and it was ice cold. This was 2 days ago, on my way home today I tried it out but it would only blow hot air. So when I got home I checked to see if the compressor was running and it wasn't. So I gave it a couple of taps and it kicked on and the air started to cool. Does this seem to indicate that the clutch is the problem? or am I missing something? I will do some more searches on this but if any body has had any similar problems please let me know any help is greatly appreciated.
Mark
Old May 10, 2006 | 08:49 PM
Blue 4X4's Avatar
Anybody have any input?
Does anyone haved the part # for the clutch kit?
Old May 10, 2006 | 10:07 PM
Quintin's Avatar
There's an intermittent open in the field coil assembly of the clutch. You really should replace all three parts though, the field coil, pulley, and flexplate assembly.
