No Floor Heat Or A/c
No Floor Heat or A/C when switched to floor position
Heat and a/c work fine except when set on floor or any combination including floor.Boy are my feet cold.It's a '97 4.2 v6 5spd.Any tips would be much appreciated.
thanks in advance,
Chop Dog
thanks in advance,
Chop Dog
thanks for the suggestion.i hate to sound like an ametuer but where is the vacuum line to the heater located.i had the floor cover on the tranny tunnel off a while back and it wasn't obvious to me(or maybe i'm blind).thanks brian
The vacuum line you might be having problems with are the ones that open air movement to the floor.I believe Its located on the drivers side under the dash to the right of the gas pedal.If you look up and to the right you'll see a round cylinder with 2 vacuum lines going to it.this is what opens the air flow to the floor vents.With it set to floor and the heat on try to move the arm above the cylinder to see if you get air movement.If you do I would inspect the lines and make sure you dont have a leak.
