Where do the HVAC vacuum lines go to?
Old Nov 3, 2005 | 01:11 PM
Propain's Avatar
Couldn't find much on the HVAC vacuum lines through the search feature, so here goes...
I'm moving my controls to a new location and I'd like to run all new vacuum lines if it isn't too labor intensive. If it is, I'll just use connectors, but I'd prefer to avoid the potential for any leaks. So, how long are the factory vacuum lines, and where do they run to? What all needs to be removed to access the initial point?
Old Nov 10, 2005 | 11:46 AM
JMC's Avatar
JMC
25 Year Member
Make model and year of truck would help in answering.
JMC
Old Nov 10, 2005 | 06:40 PM
Propain's Avatar
Good point. :o
97 F-150
Old Nov 22, 2005 | 05:46 PM
JMC's Avatar
JMC
25 Year Member
Just above the accelerator pedal is the main connector for the Control panel that is below the radio. They snake their way upto the control panel by going behind the floor panel. The floor panel pops out by unplugging the plastic push pins. Fortunatly the lines are color coded. You need only cut the lines and add more hose to reach where you plan the relocation.
JMC
