A/C always on?
Old Jun 15, 2006 | 06:19 PM
Wild Bill's Avatar
A/C always on?
I haven't driven my F-150 much since I bought it new, but I'm driving it a lot more now and I've noticed the A/C is always on at any setting on the ventillation controller (other than off).
It comes on with Panel/Panel& Floor/Floor settings. I know this because the temperature drops down much cooler than the outside air when I have the selector turned down to the lowest heat/cool setting. I thought the Panel/Panel& Floor/Floor settings are only supposed to provide outside air, are they not?
I know the A/C usually comes on with defrosters in most vehicles. Is it supposed to come on with any setting on my truck?
Old Jun 15, 2006 | 09:19 PM
Quintin's Avatar
It does this to de-humidify the air. Sounds normal to me, I wouldn't worry about it.
Old Jun 15, 2006 | 09:54 PM
Wild Bill's Avatar
I was curious because on my previous Fords it didn't do that, and on my '06 Mustang it doesn't do it either (only with A/C on or Def. on).
Old Jun 18, 2006 | 01:08 AM
Fritz_H's Avatar
If the Heritage AC is set up like it was on my '01, AC is on at all settings EXCEPT floor only and panel vent only. All other settings, the AC runs. You also get outside air on all settings except "off" and max AC. Then it recirculates. Found that in my old manual.
I prefer that system to my '05, which has separate buttons for AC and for recirc. Air temps were more consistent from vent to vent in my '01 than they are in my '05, also.
Old Jun 18, 2006 | 10:23 AM
projectSHO89's Avatar
If you read your owner's manual, you will find that the compressor runs in all positions except VENT, FLOOR, and OFF.
Steve
Old Jul 26, 2007 | 06:20 AM
a1canuck's Avatar
do you know of a way to stop it from working in ALL POSITIONS even floor?
Old Jul 27, 2007 | 02:11 AM
memLT-1's Avatar
My 06 has auto temp and you have to manualy turn the a/c off but the auto yellow light will stay on and the fan will run but you will only get ambient air from outside. There also should be an off button where you can shut everything off.
