Low heat/engine running cool
Hi everyone! Thanks for taking the time to read my post. My question is simple. What is the most likely culprit for the following....
I own a 2001 SC w/5.4 . Never had a heat problem before. Since it has gotten cold this year, the heat output is pretty weak. I noticed too that the engine warms up initially to a normal temp. At that point, I get nice, hot heat. Then the thermostat opens and the engine temp falls to just off the cold mark and remains there no matter how hard I drive the truck. The heat output at this point is weak. It's still warm, but nowhere near what it should (or used to) be. I am thinking coolant mix or worn out thermostat.
Thanks,
Tirant
Thanks,
Tirant
Sounds like your thermostat is sticking in the "open" position. You might want to check you temperature adjustment ****. They have a bad habit of cracking where the **** goes on to the shaft of the rheostat. Just pull it off to check.
Thanks,
Tirant
Thanks,
Tirant
Happy Truckin
Okay, it was -4 to -7 in and around the twin cities this morning. I let the truck run for about 10 minutes (was sitting outside). I then drove it 35 miles to work, it never got into the normal operating temps and i really had not heat either. Does this sound like a thermostat that is stuck open, or shoudl i just try the cardboard in front of the radiator to see if it will heat up?
Thanks!
Thanks!
