F150 2001, Blend door problems
Old Apr 5, 2006 | 01:25 AM
Knucklebanger's Avatar
Hot air blow on and off when temperature control **** is on cold. Is this the blend door, motor, or broken shaft? If so, how do you get to it to fix it?
Old Apr 5, 2006 | 09:09 AM
projectSHO89's Avatar
Read several of the many blend door threads.....
A well-covered issue already.
Steve
Old Apr 8, 2006 | 10:03 PM
BLUE20004X4's Avatar
Mine did the same thing and it was the blend door, replacement was around 75 bucks Canadian and labour was around 150, I believe it took 3 hours and all the diagnostic blah blah blah. I didn't want to do it so the dealer did.
Old Apr 9, 2006 | 07:19 PM
Thanks for the info. I have looked at the threads, some are for Expeditions and other F150 years. Do you think they are all similar? Is there an easier fix without taking the dash out? Once again thanks, I'm new to this forum stuff.
