EATC - Only through defrosters??
Old Sep 16, 2005 | 05:28 PM
daletina's Avatar
Unhappy EATC - Only through defrosters??
My air conditioning only works through the defrosters?? When I try floor or panel it still only goes through defrosters but when I use "vent" I get air through the panels as expected. I believe I have checked all vacuum hoses - and have run the diagnostics on the EATC without getting any error codes - Any suggestions?? 2003 King Ranch with EATC
Old Sep 20, 2005 | 01:26 PM
cg208cm's Avatar
Same Problem
I am having the same problem. Mine does come out of the vents but only at low RPM.
Old Sep 24, 2005 | 04:45 PM
wstafford's Avatar
My 97 did that with heat. It would only go through the defroster when set to floor. Dealer did not fix it so I took it apart myself. There is a vaccuum motor at the floor that redirects flow. There is a small rod the connects to the door. Mine had slipped off and infact did it again until I bent it in a manner that would not let it slide off. Ihope this helps, Bill
