View Full Version : Engine
  1. why is my truck dying?
  2. New HPS Intakes are ready too ship
  3. Oil Treatment
  4. Location of o2 sensor with P0135 and P0155
  5. Raising Drive Idle?
  6. More Power???
  7. Spark plug tool
  8. 2004 5.4 3v tapping at all RPM ranges
  9. Need to buy a scanner
  10. A different kind of noise
  11. That time of the year? Winter Fuel
  12. 1998 4.6 L Engine swap... stick with same year???
  13. I need pictures!
  14. P0300 code 2006 5.4L 3v
  15. Altenator Question
  16. Cleaned My Throttle Body
  17. 200,000 Mile Club.....
  18. What ELSE can cause P0175 fuel-too-rich? Grrr!
  19. OBD codes 0021, 00022
  20. HELP! very weird thing happened today....
  21. Steal gas through fuel filter?
  22. Govenor
  23. Sorry to beat a dead horse BUT......
  24. F150 Start Problem....
  25. timing for 4.6?????????
  26. Unknown trouble code!!!!!
  27. Truck Stalls at Low Idle
  28. Ebay coils for 3v, opinions?
  29. Mileage - I've always believed this... but....
  30. Questions about a 4.6 to a 5.4 swap in a 1998 f-150
  31. Question
  32. Who took the photo of 4.4 diesel?
  33. Have a code on a 08
  34. Misfire Problem HELP!!!
  35. fuel injector tapping?
  36. Problems after coil changing
  37. CEL on with code, Needhelp
  38. fuel economy on an 81?
  39. Stoping misfires..help
  40. stumble/missfire
  41. BBK underdrive pullies mileage increase
  42. 5.4 Block heater install
  43. shudder/bucking
  44. 94 f150 4.9L 4wd efi won't start
  45. Hex/Thread/Seat came off of spark plug...?
  46. Throttle body spacer
  47. Ford dominates engine masters challenge
  48. 95 f150 loss of power
  49. 4.9 L 6cyl F150 stumbles when warm
  50. Fuel system problem
  51. Misfire questions...
  52. engine swap
  53. high rev on startup
  54. Kenne Bell Boost a Spark or MDS
  55. 1998 4.6L edge evo???
  56. what size alt (amps)
  57. Starter Nightmare Continues!!!
  58. Engine missfire troubles
  59. chirp/squeel ---tensioner or pulleys?
  60. Weird Thing Happened Yesterday!!!
  61. 4.6 Won't start
  62. I'll tell you a tip about spark plug porcelain - you DON'T need to break it out
  63. gear ratio codes?
  64. 1998 4.6
  65. 2008 5.4 3V spark plug revision build date?
  66. E85 anyone?
  67. Rattle from engine caused by buildup?
  68. Serious Starter Problem
  69. 05 F150 power steering help
  70. PCV question
  71. 2001 Ford 4.2L V6 camshaft synchronizer
  72. New Coil Packs ?
  73. O2 Sensor(s) - 2001 5.4L "L"
  74. How much boost on stock 05 5.4l???
  75. 2001 F150 No Start and outta ideas..help?
  76. I'm still amazed
  77. Tapping / Knocking sound
  78. mobil 1 to amsoil
  79. Help engine or transmission????
  80. Banks 1 and 2 Running Lean
  81. thanks jmc
  82. help
  83. Help
  84. 5.4L sohc supercharged
  85. which e fan to buy HELP!!!!
  86. 6 out of 8 broke and then.......
  87. New main rear seal leaking, what can i do....
  88. Changed plugs, did PCM relearn, engine stumbles.
  89. Smoke
  90. cause of ticking/tapping sound?
  91. should i get buy this or this???
  92. Engine cleaning
  93. 1998 f150 specs?
  94. Gotts Intake (Air Intake Modification)
  95. air box question
  96. Spark plugs and Oil??
  97. Smashed Cats need some advice.
  98. Possible TRS problem?
  99. CEL will NOT go away! help!!!!!!
  100. BBK underdrive pulley set
  101. ok guys, really need your help, starting problems
  102. How do i make my own e fan?
  103. Help asap
  104. what is an e-fan
  105. Missfire problems
  106. SES on-> 75K Idiot Light?
  107. Speed control on fire
  108. Mobil 1 0W-20 Advanced Fuel Economy Oil
  109. Low knocking sound upon cold startup
  110. Starter Question
  111. Fuel Injection Service (Dealership)
  112. code p1405
  113. Where can i get a rotunda tool ??? Asap!!!!!!!!!!!!!!!!!
  114. want more power out of my 98 f150 4.6L
  115. misfire please help
  116. What's So Special About A 2001 4.6?
  117. Poor gas mileage...done it all
  118. changing hose and antifreeze
  119. Do I have Failsafe?
  120. Emergency Stealership Question!
  121. 5.4 2V to 5.4 2V swap
  122. cruise, BRAKES, HILL, OUCHHHH
  123. P0307 plus flashing SES light
  124. P0506 help!
  125. Starting my ford with bad starter???
  126. belt tensioner
  127. Hesitant Acceleration, Bad Tach Readings, engine tick
  128. Click Klack noise from the engine???
  129. Royal Purple vs. Mobil 1
  130. Help with P0402
  131. Horrid gas mileage in a 98 4.6L
  132. Superchips HELP
  133. 1996 F150 Duel Tank Problem
  134. Engine Blown
  135. Gasket Kit
  136. need help 1997 f150 4.6
  137. where the timing marks?????
  138. Fords $5698 pinging noise
  139. High Idle
  140. 10000 mile mark
  141. 5.4 Build
  142. What to do when you strip a torx head...
  143. I got a new engine!!!
  144. Engine Blown/Seized?
  145. clutch fan change question
  146. More gas mileage
  147. Any 5.4 2v to 5.4 3v swaps in here?
  148. P0171 (System too lean bank 1), P0174 (System too lean bank 2)
  149. New F150 Owner...any advice?
  150. v10 rough idle all of a sudden - help
  151. Cylinder diagram 02 v8 4.6l
  152. 5.4 crate engines
  153. 96 5.8 tensioner pulley
  154. Jet Engine sound under hood?!?!
  155. 98 F150 with 5.4L engine miss - stumble
  156. ScanTool TPS shows 17% idle, 75% floored?
  157. what now
  158. Time for spark plug change: anything else?
  159. changing the oil pressure sensor on a 5.4l 01 4x4
  160. 94 4.9 Fuel Pressure test
  161. AVERAGE MPG 5.4l 2006 MODEL. PLEASE POST YOURS
  162. 5.4 Horse power?
  163. Engine Tick not the injectors
  164. Mass Air Flow Sensor and chip tuning
  165. jb weld temp fix
  166. Engine Not Firing, need help
  167. Should i do the PI swap?
  168. help help help!!!!!!!!!
  169. Rough Idle+starter issue
  170. denso iridium plugs
  171. Sparking Plugs Popping Out
  172. air intake
  173. who has completed a 4.6 to 5.4 swap?
  174. gas mileage on a brand new truck
  175. Brochure
  176. spark plugs and manifold studs, fuel filter
  177. So i got my truck back from ford.
  178. spark plugs in a 2006 Screw 5.7
  179. **what is this**
  180. engine power adders?
  181. Wot!!!
  182. 98 f-150 missing and engine light bilinking.
  183. High Mileage and Synthetic Oil
  184. Water temperature sending unit location
  185. High-Jacked this thread, but 4-Sale
  186. 4X4 Lightning??
  187. Should I have thrown a code?
  188. 2 problems: starting & steering
  189. 3 Starters in 5 years??????
  190. Slight Acceleration shudder and engine light question
  191. Idle in drive issue?
  192. Bad fuel milage
  193. 4x4 lo light?
  194. 4.6 to 5.4 harness swap help
  195. $17,700 and a Warranty
  196. Ugly sound while cold star up
  197. Engine hesitating or missing 2003 Supercrew
  198. 4.6L build
  199. Truck wont start (DTC p1000 & p1260)
  200. bad misfire
  201. off road over heat
  202. Strange engine noise
  203. 5.4L upgrade cost?
  204. This is just rediculous now
  205. 2008 f150??
  206. Navigator Heads on F-150
  207. Maf?!
  208. Problem When Trying To Start!
  209. Plug change @95K with 4.6L
  210. can't get it to start
  211. fuel pump
  212. Upgrades Poll
  213. Death has freed me!
  214. TB spacers??
  215. Too good to be true???
  216. f150 2008 spins but no start
  217. Hard start
  218. Power question??
  219. 98' 5.4 running rough & stalling @ idle.
  220. engine sputtering
  221. msd coils
  222. quick question
  223. hotter plug recomendation
  224. Best Oil to use for a daily driver 06' Mark LT
  225. 1993 Ford F150 fuel problem
  226. Differnece between GT 4.6 and Triton 4.6
  227. Using/Losing Oil!! Please help!
  228. Exhaust Manifold torque sequence
  229. planning to build a 4.6 to put a lightning blower on
  230. '74 351c v8
  231. My gas truck sounds like a diesel.
  232. Engine Misfire Question
  233. Popping in AF1 intake
  234. Cylinder head overheating?
  235. engine ping?
  236. The weirdest thing....
  237. 2002 Intake Manifold Torque and Procedure
  238. "Ford Tough" ain't no joke !
  239. 99 with 5.4, no start
  240. 4hi but no 4low
  241. Most likely IAC but want another opinion
  242. motor squeal...
  243. Scott's Efan build, complete write up
  244. quick question
  245. whats the easy way to pull the engine in a 2001
  246. Fuel pressure problem
  247. Catalytics Clogged?
  248. 5.4L 3v PLUGS - What did you swap to and how do you like them?
  249. How can timing change?
  250. Hydrogen
