5.4 camshaft
5.4 camshaft
Hey guys, my motor smoked the camshaft. A roller follower went bad and wasted one lobe on the cam. I'm about to remove the cam and replace the oil pump, tensioners, follower and camshaft.
My question is....
can I have the camshaft polished? Its just rough, not chipped or melted.
or, where is the best place to get a replacement cam? its $250 at Ford or $120 for a aftermarket at Rockauto.
Also, I'm concerned with fitment of a new cam in my 106k mile head.
My question is....
I started reassembly. Progress has been slow. It's so hot in FL I don't want to work in the driveway
Got the new cam andoil pump in. Then I timed the engine, and put the new tensioners on. All that's left is to install the rockers and put the covers on.
I'm hoping that with the upgraded oil pump and tensioners this will get me to 300k
Great! I couldn’t be happier. I’m 2 oil changes in and about 6k miles including a trip across the country. Still runs smooth and I know if it happened again I could fix it in a quarter of the time because I have the experience of having done it once already.
That’s awesome, congratulations. My cam journals and caps have some scoring I found out when doing my timing job. Im just looking to hear from someone that was in the same situation and how it turned out in the end. I did have to get a used cam in the driver side so I’ll probably use those caps with that cam upon reinstalling which I’m getting close to doing now. I’m using all OEM parts (phasers etc) along with the upgraded Melling M360HV oil pump. In your opinion, should I be concerned? Car sounded great before except for the phaser knocking sound. Thanks for the input.
all of the followers have to come out to set the timing. I tried to count The teeth the first time and had to do it over.
Two things I wish somebody would've suggested to you in this thread, JFranzoo....
First off, Fram filters are about the worst thing you can do for your engine. They've historically been absolutely horrible, and I've even talked to a friend who traced multiple engine failures to his use of Fram filters.
Second, if you want that engine to make it to 300k, you need to get a cam phaser lockout kit in there ASAP. I don't know why the phasers just slowly destroy themselves, but they love to. Also, if you ever have to replace the phasers themselves, NEVER use Dorman. Motorcraft is the way to go. (but hopefully you'll never get to that point)
