5.4 Nightmare.
5.4 Nightmare.
Bought a use 2010 Expedition with a 5.4, by the time we got it home it started running bad. checked everything and finally found a bad rod bearing, had the motor rebuilt (long block). Installed it and it would not hold oil pressure at hot idle, pulled and rebuilt again. Installed again, now it barely idles and the brakes are acting up like it is losing vacuum. Pulled intake three times looking for leaks, nothing found. Once it get hot it dies and will not crank again. Very little power when running. Any help would be great.
easy way to test for vacuum leak, block off the intake tube. I like to use a plastic cup. and then try and crank the engine.
it it sucks the intake tube accordion section down, you dont have leaks.
if you hear it whistle, thats your leak
if it actually cranks up and runs you have a massive vacuum leak
as far as lack of power, KISS (keep it simple stupid)
check for proper air, fuel, and spark
air we covered above, also check for clogged air filter. Compression test if necissary
fuel, simple fuel pressure check
spark, simple spark test
that being said the 5.4 3v is a bit temperamental and can frustrate even an experienced technician.... Its even worse dealing with a 3rd party engine rebuilder.... they can cut corners and end up forgetting something like an oil galley plug in a head which then means no oil pressure
Alright, update---- Removed the valve covers and found the #7 cylinder intake rocker arm laying on it's side hung between the cam lobe and cam bearing housing. Has rubbed part of the lobe off and worn away the side of the rocker arm. Called rebuild shop who said this happens all the time, probably just when they do a motor. Anyway, they supplied a new cam, lifter, and rocker arm. I will install this weekend myself so I can make sure it's done correctly.
