shut off
Old Feb 16, 2018 | 06:14 PM
thunderboltF1's Avatar
shut off
04 f150 4.6 triton sxt (115000miles) spark plugs nvr changed, only alternator an pulleys replaced on truck
the trucks alternator went out 3 months ago i replaced it.
normally in -0 temps the truck does well an it struggled this year,
the truck started fine one morning an half way down the block the truck shuts off
im changing the spark plugs now should there be anything else i should check
Old Feb 16, 2018 | 06:31 PM
Labnerd's Avatar
I highly doubt the plugs caused the shutdown. You probably need to be checking the fuel pressure too. If you haven't changed the fuel filter, now would be a good time. More than likely though once you change the plugs, you're going to have a miss in the engine. You'll be changing the COPs and soon or you can do it now. The O2 sensors should be changed every 80,000 miles. You only need to change the front ones- MOTORCRAFT PARTS ONLY. The PCV should be changed every 50,000 miles, again, MOTORCRAFT ONLY. Make sure to use a di-electric grease on the shanks of the plugs when installing them. NO anti-sieze is used on that engine.
Old Feb 16, 2018 | 07:49 PM
At 115k, the plugs are overdue. Use Motorcraft plugs, no antiseize, torque to 28 ft/lb. I don't see the need to change the coils, but I'd replace the boot and spring kits. Dielectric grease goes on the inside of the boots, not on the plugs. Fuel filter should be changed every 30k. O2's don't need to be changed till a scanner shows them responding sluggishly or gas mileage drops with no other explanation. PCV doesn't need changing these days unless it's gunked up and doesn't rattle when you shake it. Check the FPDM for corrosion.
Old Feb 16, 2018 | 07:56 PM
Yup, like glc said, check the FPDM.
