2004 Spark plug tips
Old Aug 28, 2018 | 05:56 PM
greg1100's Avatar
I have a f150 2004 5.4
hello just informed my check engine light is on due needing a tune up
You mentioned plug remove is a concern due to breakage . How common is this a problem. Or is there a way to be more proactive with the removal process.
I was concerned with a 800.00 quote for performing the work at a dealership.
Old Aug 28, 2018 | 08:39 PM
Thread you should read:
https://www.f150online.com/forums/v8...g-removal.html
Plenty more threads here on changing 04-08 5.4 3 valve plugs. 800 bucks is high, find a different dealer. I'd expect 300 bucks plus 50 for each broken plug.
Old Aug 29, 2018 | 10:07 PM
heres my thread should you choose to attempt it yourself
https://www.f150online.com/forums/v8...s-55-56-a.html
im actually past due to update my thread. Was called to remove a broken plug, and then get the other 7 out after he was scared to continue
