View Full Version : Pre-1997 Models
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. 94 starting problem
  2. Replacement Center Console?
  3. Fiberglass running boards
  4. Sagging Front Bumper
  5. good website for shopping
  6. exhaust questions
  7. New to Forums
  8. 89 4.9L timing
  9. 1981 Ford Rough Idle/Low Spark?
  10. What color ghost flames on black truck
  11. Build sheet
  12. 4" supsension lift
  13. f250
  14. hitch q-
  15. Anybody w/ pics of Edelbrock's 351W truck intake/plenum?
  16. 20s??
  17. rab-1 draging brakes
  18. Starter Shield
  19. Air bag code 3 3?
  20. Decoding the door sticker
  21. Leaf Spring movement... making noise
  22. 302 throttle body and intake Q
  23. Ho 302
  24. Hey I am new ... well kind of. (SEE PICS)
  25. tranny on the way out?
  26. rearend gears
  27. was this a good buy?
  28. 4.9 pics
  29. F150 Pulls hard
  30. fiberglass bed lid for sale in IA
  31. vibrations????
  32. Lifting a 95 2 WD
  33. rear driveline won't slip onto splines ('96 F150 2WD)
  34. arcing?
  35. Alternator Not Working?
  36. 4.9 hose pressure
  37. Some troubleshooting help?
  38. Can an '86 top go on a '94 Bronco?
  39. What can I do?
  40. 91 f150 dual tanks capacity?
  41. switch
  42. dual tanks suck ass/selector keeping my truck from running?
  43. Replacement Seat Cover
  44. Oil pressure drops with throttle?
  45. Parking break does not work!!!
  46. Question about daylights...
  47. 93 F-150 AC Vacum Issue
  48. 95 Ford F150, overheating issues
  49. 302/351 swap DONE
  50. '95 F150 4.9L V6 automatic -- fuel filter??
  51. aftermarket tach install on 89 F150 302
  52. solenoid
  53. I finally got to do it.
  54. New Engine on the way
  55. Anyone have 35"
  56. How to remove 5.8 fuel rails?
  57. What wrench is needed to remove center 5.8 manifold bolt.
  58. change odometer from miles to kilometers
  59. Performance engine
  60. New bad sound on good old truck
  61. 88 longbed same size as a 95 LB???
  62. Wants To Stall Help
  63. Quick connect to charge AC on '94
  64. 5.8 / 351 Fuel Pressure
  65. New Development of Jerky/ Dying Truck
  66. Grease Points
  67. dual gas tanks??
  68. '92 Ford F-150 3.9 I-6....HELP!!!!
  69. Runs great, gets jerky, then dies
  70. 95 Lightning tech questions - HELP
  71. 96 f150 5.0 dies wont restart
  72. seat belt help!
  73. Anyone Done a 302 based Stroker
  74. How to test fuel pressure
  75. stalls when idle ?
  76. whats my engine?
  77. little bit of a problem
  78. Cam specs?
  79. wheres the switch for the backup lights?
  80. how can i prove that my 78 for is noncatalyst?
  81. lpg conversion?
  82. Tie Rod Problems on 86 F150 4x4
  83. What causes dieseling?
  84. low oil pressure
  85. 92 F150 5.8 Engine Codes 181 334 542
  86. 93 lift
  87. 1990 f150 passenger SIGNAL LIGHT
  88. winch bumper suggestions for '88 F-150?
  89. Wiper Control Module
  90. Visual difference between EFI & MFI?
  91. '94 "Wont Start" problem
  92. Towing Capacity
  93. New Pics
  94. Got myself a '90, have some questions
  95. Attention Beastie
  96. help w/ lifting my 95'
  97. Press brake to start or selenoid going bad?
  98. tick me off
  99. 94 F150 4.9L What Happened???
  100. Stall Speeds
  101. 87 F150 Warm/Hot Starting Problems
  102. Hitch recomendations
  103. fitting 33" tires....2" body lift work?
  104. OK...got codes got stuff..still got issues... Suggestions?
  105. 86 f150 running terrible...
  106. Speedometer Cable Part Missing ?
  107. Rebuilding '90 5.8, can I junk the smog?
  108. 94 4.9 straight 6
  109. What am I sitting on??
  110. '96 302 Won't Start When It's Wet/Damp Outside
  111. Anybody "true dueled" a '96 302?
  112. who should win
  113. where oh where has my inertia switch gone?
  114. armrest in 93 bench seat
  115. Some pictures of my truck
  116. Rough idle/cruise 93 5.0
  117. looking for pics of 95 with 33" tires
  118. Looking at a '95 4x4 ... advice?
  119. differences in the E40D
  120. hi end miss 300 inline 6
  121. Advice on 1985 F150 300I6?
  122. Tire size for stock 15x7.5 wheels
  123. Mlps
  124. Transmission shift points?
  125. Engine Temp
  126. OEM CD player for '94 F150
  127. torque / fuel ecomomy
  128. truck won't start!!!!!
  129. What is this on my motor???
  130. 2 problems: steering, bed liner
  131. im happy
  132. bumper lights
  133. If not the starter, then what?
  134. 4.9 V6 Missing and Acceleration Problems
  135. Seat Swap?
  136. Sway Bar Upside Down?
  137. stereo wiring
  138. Broken tilt on 91 f150
  139. wiring harness (HELP)
  140. Keyless Remote
  141. spark knock?
  142. 92 F150 Find!
  143. Truck weight
  144. Replacement Engine/Swaps
  145. How to get trouble codes? Switch on/off??
  146. 94 f150 heater core
  147. Swapping C6 for E4OD?????
  148. high milage 95 to tow 4500#?
  149. Driver's door
  150. truck beds
  151. pcv valve
  152. squeaky steering???
  153. Water Pump bolts wont go back in
  154. Rear window motor on Bonco
  155. Wont come out of park?
  156. No Keyless Entry
  157. Biggest Lift and Tires
  158. 1996 F-150 with slight stutter at highway speeds
  159. leaking fuel tank
  160. engine noise, is this normal?
  161. safari light bar
  162. towing a 3 horse trailer
  163. 95 F150 Performance?
  164. My great fun 91!!
  165. What's your problem???
  166. extend cab on regular cab frame
  167. 91 f150 door panel removal???
  168. Strong coolant smell?!?!?!?
  169. 6-8 Mpg. Help!
  170. Thoughts on high mileage '90 F250 5.8 purchase
  171. A Good Deal, Or Not....
  172. 1987 brake problems
  173. Header recommendations
  174. Oil in the Air filter Box
  175. 1994 F 150 Parking Break Cable
  176. Spark Knock
  177. 05 engine in 86 feasible?
  178. 1990 audio system
  179. Newbie here
  180. what heaers for GT-40p
  181. 4.9l Starter
  182. Finally!
  183. Ack... no start and no codes
  184. Ignition Cylinder
  185. overdrive button came off
  186. location of oil pressure sensor on 1987 F150 5.0
  187. How Much Is My 94 4x4 XLT Worth?
  188. Dual Tank Selector Value
  189. 95 F150 2wd lift help please
  190. lifting the front end on my 94
  191. Code 538 Help?
  192. Tach in 80-86?
  193. Bigger Radiator with a 4.9 Strait 6??
  194. '88 F150 I-6 to 351 swap, what do I need?
  195. fuel pressure
  196. Just bought my first truck! Many noob questions inside.
  197. how big of tires u got??
  198. 87 f150 problems continue
  199. is the A/C really worth fixing?
  200. Johnny Unitas' personal 1986 F150!!
  201. A/C Low Side Service Port????
  202. Long tube Headers 95 150
  203. Ignition timing procedure 96 f150
  204. wants to stall/loses power on accel
  205. 93 f150 gauge question
  206. loud winding noise when starting truck
  207. Speedometer Gear(the one in the T-case)
  208. what is the best pre 97 f150?
  209. Fuel mileage on 1980 F100 with 4.9 six-cylinder
  210. Serpentine Belt
  211. Fuel Injected or Fuel Injection? HELP!
  212. '90 F-150
  213. Whats ringing my bell/chime
  214. Rust on 95' F150
  215. Best way to boost power??
  216. Starter question???
  217. installing a starter
  218. Switching From Carb to EFI
  219. 91 f150 clunking noise???
  220. 5.0 truck setup
  221. Fuel Filter Removal
  222. 1996 Ford F150 idle problem
  223. too cold?
  224. Quick Question, Help
  225. What sensors on a Transfer Case on a 89 F250?
  226. Newbie with a ? on a 93 5.0
  227. CEL or SES on '94 F150?
  228. 1990 Chevy camper shell on 95 F-150?
  229. oil pump in a 302
  230. Combination Manifold
  231. Hiya!
  232. soft brake pedal
  233. 1994 Questions (VSS and fuel pump) ATTENTION PKRWUD
  234. Mulitiple problems
  235. cold air
  236. Front Gas Tank Leaks (1994 F-150)
  237. Fixing up used '95 F150
  238. eec 122 - TPS voltage low
  239. Stuck Auto Hub
  240. Trans slipping when hot
  241. Newbie 4x4 Questions
  242. What should I offer this guy?!
  243. I6 wierd problems
  244. ebay resistor
  245. Cats: Necessarry?
  246. back fire on idle
  247. 89 f150 exhaust question
  248. Help for the Ignorant!
  249. Hello... noobie here
  250. Auto trans to Manual
