kickdown
Old Aug 5, 2010 | 10:27 PM
85 f150's Avatar
kickdown
I need to know if there is a aftermarket kickdown rod for a 4.9 witha four barrel. Conversion went smooth but def need a kickdown any sugestions?
Old Aug 6, 2010 | 12:35 AM
What transmission are we talking about here?
Old Aug 6, 2010 | 07:17 AM
85 f150's Avatar
sorry C6 Auto
Old Aug 7, 2010 | 03:47 PM
Steve83's Avatar
Why not use an original kickdown rod??? Try JBG, LMC, etc.
Old Aug 8, 2010 | 07:18 AM
bigbronc's Avatar
If the carb has a kickdown lever on it (some 4 barrels don't), you should be able to modify the rod to work. If not, don't know how you'll do it unless you pull the gearshift into second to pass then shift back to drive. That is all the kickdown does only the built in one allows only so much speed before it will automatically upshift. If you pull the shifter, you stay in 2nd gear.
