86 f150 trailer wiring help
Old Sep 2, 2010 | 11:48 AM
vettekid12's Avatar
i went to uhaul to rent a tow dolley and the trailer lights wouldnt come on. i have an 86 f150 and everything works fine but now the trailer lights dont come on. could this be a grounds or a short somewhere. and what fuse do i check for this as i dont have a fuse cover.
Old Sep 2, 2010 | 01:21 PM
77mud's Avatar
Im asumming 4way? did you use a light tester and check and make sure your truck has power at the plug?
Old Sep 2, 2010 | 01:27 PM
vettekid12's Avatar
ok. before u posted i went out under the truck and took a peek at it. the harness is a 7 prong harness and also has a 3 prong harness for diffeerent types of trailers. and the one i was trying to use was the 7 prong with adapter from uhaul to make it a 4 wire harness. so i looked at harness and all the wires are bare with no covering on them. so i am going to take the complete harness off and rebuild it. so i know it works
Old Sep 2, 2010 | 04:32 PM
Steve83's Avatar
I suggest you get an old edition of the Haynes manual (the oldest blue-cover you can find) and wire it up the way '92-96 trucks are wired, using common Bosch/ISO relays & sockets as shown here:
You can buy standard blade fuse holders & MEGA fuse holders at most parts stores.
Old Sep 2, 2010 | 08:30 PM
vettekid12's Avatar
haynes manuals i have the one for my truck would the wiring be the same? bronco f150 are in same manual. would it be better for me to have a shop rebuild one for me. and have my rear lights installed and put int the same harness?
Old Sep 2, 2010 | 10:42 PM
jgger's Avatar
Go to electrical forum and look up trailer plug issues. I had a recent "adventure" with the plug and SScully gave me a diagram at the end of the thread.
I say go to because I'm not very good at posting links.
Hope that helps.
Old Sep 3, 2010 | 08:33 AM
77mud's Avatar
Yes all trucks are wired the same way for the trailor lights
Old Sep 3, 2010 | 11:18 AM
Steve83's Avatar
The trailer connector itself is always wired the same, but the way it's connected to the truck changed over the years (fuses & relays). So follow & mimic the circuits in the '92-96 diagrams; not the older ones. The diagram SSCULLY posted shows the same info as the one I posted above.
Old Sep 4, 2010 | 04:31 AM
vettekid12's Avatar
alright thanks guys. ill take some pics of the before and after or it. so u can tell me what ya think
