DZanEana 44 gear ratio
Old Jul 21, 2010 | 07:43 PM
Samson-owns-you's Avatar
Just curious if there would be a way to check the gear ratio in my axle I bought. I can't find a tag, and I really don't want to have to pull it apart as it's all intact.
Old Jul 21, 2010 | 08:05 PM
77mud's Avatar
Mark your axle and your pinion spin the pinion until the axle goes around 1 complete time and count how many times you spun the pinion that should give you a general idea...
Old Jul 21, 2010 | 09:20 PM
Ya but I'm tryin to find the exact ratio so I can redo my rear to match. I didn't know what all ratios were available. I was worried about mixing say a 4.11 and 4.10 and obviously having a problem.
Old Jul 21, 2010 | 10:28 PM
Code's Avatar
Pull the cover and count the teeth on the ring gear and pinion. divide the number of teeth on the ring with those on the pinion.
4.11 and 4.10 shouldn't cause an issue. I have 5.13 in the front and 5.14 in the rear of my explorer.
Old Jul 22, 2010 | 08:37 PM
77mud's Avatar
4.10 and 4.11 arent gonna mess you up PERIOD, as code said pull the diff cover and count... you want get messed up unless you go with a 3.73 and 4.11 and then you want aslong as your only in the mud... in some of our mudtrucks we run 3.73 rear and 3.07 front granted we have 44's rear and 38's front
Old Jul 23, 2010 | 07:43 AM
Ok, I'll get up there tommorow and pop her open. Thanks for the assistance!
Old Jul 24, 2010 | 12:03 PM
LOGANSTANFORTH's Avatar
Early broncos were 4.11 and 4.09...
