Old Aug 9, 2010 | 04:19 PM
C. Furr's Avatar
1992 5.0
I have a 1992 F150 with the 5.0 302 V8 with auto trans. I have been having an issue with it cutting off on me while driving and it has been missing too. Talked to several people and they have mentioned an ignition module under the distributor. Thought I would post on here to get some reccomendations.
Old Aug 9, 2010 | 04:53 PM
bigbronc's Avatar
Need to check the basics first, plugs, fuel pressure, pull codes. Then post with more info afterwards. At this point with this much info, it could be a bunch of things.
Old Aug 9, 2010 | 11:37 PM
Labnerd's Avatar
The TFI failure usually happens when the engine is at normal operating temps. If it's happening on a cold engine, that's probably not it. The MAP sensor would be the next likely thing to check. I believe yours is mounted on the firewall on the passenger side. It'll have a vacuum line and an electrical plug going to it.
Old Aug 12, 2010 | 01:00 AM
Steve83's Avatar
This is my first guess.
Second is fuel pump or inertia switch.
Old Aug 17, 2010 | 06:25 PM
C. Furr's Avatar
OK, Changed plug wires, ignition control module, fuel filter, and air filter yesterday. Truck ran great coming home from the shop. Got in the truck this morning, hooked up my trailer and started out the driveway and it cut off. Would not start back up so I had it towed back to the shop. Got there and the truck fired right up. Called my mechanic this evening and he has drove it and let it run and cool off and is running fine. I am getting very frustrated now.
Old Aug 18, 2010 | 08:34 PM
bigbronc's Avatar
Ok, now it sounds like you have a fuel supply issue. Usually when the fuel pump goes out, the truck will restart after a cool down period, and may run fine for a day, or a month. When it won't start, you need to check the fuel pressure first.
Old Aug 27, 2010 | 05:49 PM
mossie4's Avatar
I had a 1990 Bronco with the 5.8 that I added a Vortech S/C to. Ran great around town but when I headed down the highway to SLC, I could make it maybe 100 miles at atime. Seemed like when the fuel got below a 1/2 tank, she was dead. Just like the previous post said.....after a cool down period (A long time in mid August) she would start right up again.
Fuel pump in tank....that is my guess.
Old Aug 27, 2010 | 06:58 PM
fine_style150's Avatar
its your fuel system...change to new pumps and check other things along that way, this happened to my dads truck same engine same experiences...after that shes still runnin towards the 190,000 mile mark and it feels she runs better then my 08, seriously!!
Old Sep 19, 2010 | 09:05 AM
Blueboy5k's Avatar
Sounds like the fuel system. I had a similar problem caused by the inside of the fuel tank delaminating. The lamination became a sort of rubbery sludge that kept getting hung up on the pump intake after I got the truck up and cruising. After I stopped and pulled over and shut it down for a ten minutes, it would start right back up. I wound up taking a tank from the junkyard and installing it. Afterwards, I took a look in the old tank and found the culprit sludge. I install autoglass for the DOT who in this state run almost exclusively Fords. The tech there said this is pretty common for Ford tanks after 150,000 miles. I described the sludge and he showed me one from the week before that he had removed and he showed me the sludge that was in it. It was the same stuff. Apparently it is much more common in diesels, but does occur regularly in gassers as well.
Old Sep 19, 2010 | 12:47 PM
Steve83's Avatar
The gas tanks aren't laminated - they're galvanized steel. So any sludge that you find in them is contamination; not delamination. Diesel just contains heavier oils that form deposits more easily. Read the Fuel System section of this TSB:
Old Sep 19, 2010 | 05:34 PM
Blueboy5k's Avatar
Good to know. I thought a laminated gas tank sounded a bit strange. Anyway, there was much sludge.
Old Jan 16, 2011 | 03:20 PM
C. Furr's Avatar
OK Had a different mechanic look at it before Christmas and he changed the coil. Truck done good for about a day and now it will run for a little and cut off (no fire coming out of the coil) It is not a fuel issue it is an electrical issue. When it cuts off it is like you turn the ignition off. You can let it set for a little and then it will fire back up.
Parts changed (fuel filter, coil, ignition control module, plug wires, distributor and stater)
PLEASE HELP
Old Jan 16, 2011 | 04:33 PM
StrangeRanger's Avatar
Look at post #4 in this thread again.
