window motor or regulator?
my driver window (power) wont go up. i was putting it up today got it about half way then it stopped at started falling back in. the only way i can get it up is to grab it and force it up. Is that the motor or regulator?
As an automotive Glazier here's the skinny. The regulator is almost completely bulletproof, If you hear the motor spinning, and you can "help" the window up while pushing the switch it is the lift motor. An extremely common problem for all Fords of this time period. If you hit the switch and hear nothing, connect a DVOM to the battery, and then turn the key on and watch the DVOM for a voltage drop when you hit the switch. If there is none, check the switch electrical circuit. If there is a drop and the motor doesn't spin, it's the motor.
It is super-common for these lift motors to strip the gears from the output shafts after many years use. When that happens they "skip" and spin inside the stripped gear which moves the regulator.
I have done dozens of these motors in the field. You are describing a textbook stripped out motor gear!
