Turbo 5.0L
since you gave us as vague (little) information as possible I assume you're budget will not include forged internals
therefor you probably will not get a quality turbo kit
and you probably will not want to run premium unleaded
so um yeah 1-2 # of boost might work on your motor and make you feel cooler
A proper rebuild with hypereutectic pistons and you're probably good to around 6 PSI max. Lower the static CR a bit, O-ring the block and add a turbo-specific cam and you might get to 9 PSI. Above that point you're looking at forged guts, etc. and a lot of money.
You need to do a LOT of research. Start by reading Maximum Boost by Corky Bell and Turbochargers by Hugh McInnes
