- Wet Engine "Gunked it"
- Idle Air Control Valve....Idle Issues 99 F150 4.6
- 04 5.4 Max R.P.M.?
- 6.0 diesel whistling noise
- rounded spark plug -help
- DPFE sensor
- A/C clutch not turning.
- Engine Hesitates
- Yet another 5.0L thread...
- putting together an engine?
- Gassy Smell At Idle
- The computer label = A0E1, The parts catalogs show F0PF. What gives?
- Vacuum line diagram for 2002 f-150
- Truck stalling
- Fuel Injector Upgrades
- will COP failure prevent starting
- 5.4L Tick
- What is this noise in overdrive?
- P1151 code
- 5W-20 vs 5W-30
- P401 Question
- Intake Problem
- Identify age of COP's and Injectors?
- 98 f150 4x4 4.6 engine upgrade to 5.4 question
- 2000 Expedition Intermittent Erratic Idling
- Hot air intake?
- question for LABNERD
- Cold Start Problem
- Both banks lean...Any ideas??
- 02 sensors cause misfire?
- noob here, 5.4L many problem COP #4
- Timing Cover
- trace the problem
- Mis-firing
- Engine in failsafe mode and gauges sporatic
- Burning to rich?
- hmmm serpentine belt squeal !?
- Which Walbro??
- p0171, p0174, p0304 cylinder 4 misfire
- My truck loosing its oomf....help
- Ticking
- Fuel pump shot?
- Burn more gas? F150 VS Expy
- 04 4.6 question
- burnin oil
- Code p0133 question....
- autometer oil pressure gauge....... help
- back fired ... now will not idle
- MagDrive HHO generator
- 04 4.6 supercharger
- Motoblue COP's
- 06 5.4 Bogs under slight acceleration... ????
- 2004 4.6 stalls
- couple of code questions
- Loud Engine Chugging
- oil filters
- coil packs- Global auto
- What Can It Handle.
- HELP Belt Squeel between 1200 and 1400 RPM's
- CEL #4 cylinder misfire
- Cold Air Intake
- changed alternator and tensioner now vibration
- Need new battery
- Alot of noise no go!!!
- Will these COPS work in my 06 5.4L ?
- P304 Code
- 5W-20 vs. 5W-30?
- F-150 w/ 8,000 lb Horse Trailer?
- Wet Truck
- Lightning 5.4 into 4x4
- Oil filter comparison
- Best synthetic oil
- 4.6 liter rebuild question
- Performance gearing options?
- Truck Specs
- coil help . . .
- pulleys belt and e-fan
- Helppp
- Timing Gear on Camshaft
- white smoke
- Intake Help
- 4.6 engine performance options
- P1406 DPFE downstream hose?
- Plug wires
- Dealer Charges $7.21 for quart Motorcraft Synthetic!
- what´s too fast for a 5.4 3v?
- 2004 F-150 5.4 Triton V8 Rough Idle
- Fuel injectors 5.4 3V
- Correct Vacuum Lines?
- Electrical question 2002 Altima
- 2000 suzuki swift starting problems
- 500hp 460 and a np 4 speed tranny
- 5L throttle body swap on a 4.9L
- This is the fuel super heater thing he's talking about...
- plugs
- P0358 Engine Mis
- Advise = Sprark plug issue.
- oil and lube question
- Where can you buy Motorcraft FULL SYN 5w20?
- OBD11 Code P1507
- fuel pressure.
- Need some advice
- 4.9L Performance Info
- Motorcraft plugs cheap?
- Synthetic Oil/MPG
- 4.9L over heating
- Radiator differences on 97-04 body style
- Which gasket to replace?
- will these injectors work on my truck???
- Efans, question to improve efficiency...
- type of engine you have
- cheapest price on Granatelli 4.6 COP's?
- water leak
- Weird Noise??
- Misfire Detected on Cyl 5
- Idle air control part number???
- ac compressor and belt 4.6 to 5.4?
- duel sequential turbos
- Spark plug part number
- Which V8 Engine is Best - 2008
- fuel pressure regulator?
- Life expectency
- 4.6
- Looking for AC Low Pressure Valve - 2001 F-150 SuperCab
- Transmission and RWHP?
- Junk 4.6
- Gauge Cluster Tachometer Help
- RPMs going nuts at idle
- 99 f150 leaking coolant. can't find source
- Cels P0172 & P0175
- misses in fourth gear at speeds 30 -50 mph
- Maintenance Advice Needed
- Whistling after engine is turned off
- Sigh - here I go again... O2 issues
- Radiator Hose Keeps Popping OFF!
- Hard starting
- ARP Main Studs 04+ 5.4?
- Crate Motors?
- Help!!!!misfire At 2000rpm
- new guy
- Used F-150... issues & questions...
- transplant help from 4.2 to 4.6
- Blown Plug repair kits
- 5.4L miss but no CEL??
- Engine light on
- Crank Pulley removal
- bought truck from alaska
- Broken Radiaotor Overflow Kneck.
- wrong radiator
- Cab Blower Controls and Engine Vacuum
- mass air flow location
- Underdrive Pullies - fact and fiction
- Won't Start - Fuel Sender Issue Perhaps??
- How do you replace fuel injectors?
- Trinary switch for efan
- 1999 ford f150. new engine
- So heres a new problem....
- Premium fuel w/ octane booster
- Lemon Law!
- best plugs and wires
- Looking for checklist for Lightning swap to 02 SuperCrew
- Running hot, don't know why
- Cold Air Intake
- Time For A Tune Up
- Motor ticking
- Idle Problem
- Compression test
- Some Advice
- 98 F-150 4.6- #1 plug blowing
- Engine Caught Fire - Now What?? (Pics)
- Cold Air Intake Kits - Please Share Your Experience With Them
- New Truck, Engine Issue, Throttle Body Replaced
- flutter noise between 2500-2800 rpms
- Lost
- This is going to be different but cool looking
- Just can't seem to screech em.
- Made the plunge into Full Synthetic!
- Good Job Ford!!
- 98 heater core replacement help
- Oil leak
- Help 98 4.6 f150
- intermediate shaft
- Mpg
- 2005 XL 5.4L Triton
- Desperation!!!
- Sluggish 5.4 liter
- problem please help
- Dyno appointment
- Real stupid noob question... i know i know...
- rough idol
- deseil vs gas
- HP Gains
- ho-alt and idle rpm
- Changing Plugs in 2000 Expedition, 113,000 miles......Should I Change the "Cops" too?
- are 5.4 heads interchangable with 4.6?
- TB cleaning
- AC causing misfire??
- Engine oil for towing ?
- Finished cop install...
- 5.4 idle
- rough idle 4.6
- How far can i advance?
- need some help
- how are the Motoblue coil-on-plug 4.6 kits?
- engine code question
- looking for a 4.6 or 5.4
- Warning Broken Garbage Spark Plugs
- Pfe/evp Circuit
- What is evap system?"
- 5W-30 vs 10W-30
- lightning engine swap, to a f150 4.6l
- How much for a fuel system cleaning
- changing serpentine belt
- low oil pressure?
- how much time between oil change
- thank you for your help . . .
- 4.2 V6 vs 4.6 V8
- cleaning egr ports in intake elbow
- missing ,bucking at speeds between 40-50mpg
- My 5.4 needs power
- where is the radiator fill ?
- 6psi switch removal
- 4.6L to 5.4L swap on 2002 Screw
- Radiator and Halogen lights
- Service Bulletin 5915
- 5.4 vs v10 vs PSD Longevity
- egr valve
- Engine Swap?
- AT LAST! finally ordered some cool stuff....
- fuel sending unit
- Best electric fan and tune up items
- Hydrogen added to intake- good / bad?
- Just a little info I got from autometer today
- building a 5.4
- Loud Knock & Running Rough(5.4)???
- pic of dyno run
- Water Pump Questions
- starts but dies
- Vibration between 5 and 15 mph
- Have hesitation, high RPM's, low MPG
- Is my truck running lean?
- How to test a DPFE?
- how do you use a fuel line disconnect tool?
- High RPM operation?
- Daydreaming an engine sawp (not the usual)
- Crate Engine?
- Windage tray?
- 2006 4.6 electric fan
