Need Help!!
Old Mar 15, 2011 | 12:32 PM
ironhead7619's Avatar
Need Help!!
I have a 2000 F 150 with a 4.6, it started missing so i changed the plugs out and it continued to mis. I took it to a mechanic and the only code was for the EGR valve and a misfire in #8. I changed the valve and the sensor and put a new coil on the #8 cylinder. The truck is still missing badly and will not throw a code.
Old Mar 15, 2011 | 12:58 PM
grizzstang's Avatar
How many miles on your truck?
What plugs did you use?
Old Mar 15, 2011 | 01:02 PM
Norm's Avatar
#8 is driver's side firewall.
Old Mar 15, 2011 | 01:11 PM
It has 184000 on it
Old Mar 15, 2011 | 07:59 PM
Toyz's Avatar
What kind of maintenance? Fuel filter would come to mind. Also, cleaning the throttle body, egr ports... probably clogged. New set of cop's are probably in line also.
