Fuse 32
Old Mar 15, 2011 | 03:44 PM
John Patterson's Avatar
Fuse 32
I have an '07 F150 w/ 5.4 w/apprx 95K miles. Truck started running rough yessterday. So I changed plugs again and it's still running rough. Truck goes into 'limp-home' model and check engine light also comes on. I found fuse 32 blown. I replaced it a couple of times but it continues blowing out. Truck is completely stock.
Any suggestions would be much appreciated. I would sure like to find problem before going in to dealer.
Thanks,
Old Mar 15, 2011 | 07:36 PM
projectSHO89's Avatar
Start by checking the O2 sensor harnesses to see if any are lying on the exhaust.
Old Mar 15, 2011 | 10:59 PM
My neighbor has an inexpensive code reader. Three messages were given: mis-fire on cyl 3, knock sensor on bank 1, and ignition miss.
I will look underneath and check the O2 sensors, wiring on knock sensor. And I may just go buy another coil.
