EGR valve p0401 code
Old Apr 14, 2011 | 10:18 PM
steven'sf1504x4's Avatar
First off my truck runs perfect, i have replaced the EGR valve and DPFE sensor and still the light comes on. throwin the same p0401 code. it has a smooth idle, doesnt run rough, has great throttle responce. i have done all the mantaince on it. it has 133K. i belive the EGR passages/ports on the intake need to be cleaned. im just goin on a trip to the beach and dont have time right now. im just wondering if it will be ok to drive with it like this. its actually been like this for a while, i just got around to replacing stuff. and the light is still comming on witch is aggravating. im just goin on a spring break trip and need to know if it wont hurt anything to leave it for alittle while longer. thanks steven
Old Apr 15, 2011 | 12:13 AM
jethat's Avatar
I think your safe. Had that code come up in my old van and I replaced all the stuff. finally cleaned out those tubes and it went away at least it was gone when I sold it.. I dont think its a big deal.
Old Apr 15, 2011 | 01:41 AM
If it runs good and doesn't spark knock, it's safe to drive. If it does spark knock, use premium gas till you can fix it.
Old Apr 15, 2011 | 07:57 AM
thanks guys, yea it runs good and doesnt ping or anything underload.
Old Apr 17, 2011 | 12:56 AM
i have one other question, could i just spray throttle body cleaner threw the hole were the egr bolts up to wouldnt tht go threw tht passages and clean them out or atleast soften up the carbon enough to wear the pressure in the system to blow it out of the ports.
Old Apr 17, 2011 | 03:20 PM
You don't want that crap blowing out the ports and down the intake.
Old Apr 17, 2011 | 07:48 PM
yea thats true man, thanks for the reply i was just askin cause someone else on here did that, but i figured it wouldnt be a very good idea. ill just remove the whole thing and clean it out after spring break. is it hard to remove?? i know theres like 4 or 5 bolts.
