5.4 lifter tick
What oil and filter are you using? Possibly an exhaust leak... fairly common. Could be injector pulse. Could be a plug about to pop out. Could be timing chain noise.. a bearing... Could be numerous things. Snag u pa mechanics stethoscope and see if you can pin point where it is coming from.
I don't believe it is, I will check tomorrow then. We use them on a lot of our engines, except race engines when we use wix filters.
I was trying to hear it today, and actually think it's the Cat's or one of them.. I went under the hood and couldn't hear it.. It was louder by the driver door, got underneath it and then it went away..
More investigating tomorrow.
I've had some exhaust leaks at the manifold, and yes.. they do seal up when they aren't horribly bad once they heat up. But, with some slight revs sound more like a slapping sound. At idle they will sound like a tick. Best thing to do is to get a mechanics stethoscope and try to pin point where it is coming from. My exhaust leak sealed up so good when it was warm that when I took it into an exhaust shop to have an estimate done, they told me it did not leak. Once I explained they needed to let it cool down and start it, they found the leak and fixed it.
From what I've read from all these helpful people on here, is sometimes the dealer does not torque them or worse, they use anti-seize. From what everyone says on here, plus my own personal experience, 26ft/lb with no anti-seize and you are safe from spark plug blow out. The way I was able to tell if the plugs are ok and not about to spit out, take a long extension and place one end on the coil and the other end to your ear. You will hear compression slipping past the plug, that is how I found out one of mine was loose and about to eject.
