winding noise
Old Apr 2, 2011 | 03:16 PM
znhunter's Avatar
Post winding noise
When is start my truck (Sometimes) there will be a winding noise coming from my engine compartment, it sounds like a leaf in a bicycle tire what could this be? ive read the topic about Starter?flywheel if it is could it be the same problem im having?
Old Apr 2, 2011 | 11:08 PM
Toyz's Avatar
Remove the drive belts and spin the pulleys by hand. Pay special attention to the tensioner or idler pulley. Look for any noise.
Old Apr 3, 2011 | 11:46 PM
munoxide's Avatar
If it's a "whining" noise, its probably one of the pulleys....When my tensioner pulley went, it was whining like a **** then it finally locked up and broke the belt so yea, check tensioner and idler pulleys along with the others....
Old May 28, 2011 | 10:17 PM
znhunter's Avatar
i replaced my tensioner pulley its coming from the drivers side so could it be the timing chain?
Old May 28, 2011 | 10:46 PM
jethat's Avatar
did you replace the idler pulley to? Timing chains rarely fail on these engines. Remove the belt, if the noise is gone when you start it briefly with out the belt on it is one of the things the belt turns. PS AC Idler tensioner that you replaced so it aint that..
Sometimes the timing chain guides do wear out so it coud be that..
Old May 29, 2011 | 06:08 PM
znhunter's Avatar
no i havent replace the idler pulley yet is is best just to replace both of them ?
Old May 30, 2011 | 02:00 PM
jethat's Avatar
Yes
