98 5.4 engine
Old Mar 7, 2011 | 09:10 PM
tang1987's Avatar
98 5.4 engine
Hey fellas,
I have a 98 Expedition 4X4 with a 5.4. About once a week, just after I start it and get ready to pull out of driveway or from parking lot it will almost die then come to life and after that it is fine. I have no other issues other than that. I have replaced plugs, coil packs, throttle position sensor, temp sensor, and I see no bad/broken vacuum lines. Any ideas?
Old Mar 7, 2011 | 10:37 PM
DYNOTECH's Avatar
I would try cleaning the MAF sensor and the IAC valve.
Old Mar 8, 2011 | 08:36 PM
tang1987's Avatar
will try IAC
I have cleaned the MAF but haven't tried the IAC. Humidity may play a factor i'm thinking because it has rained a lot here lately and has almost died 3 times in the last two days.
Old Mar 9, 2011 | 04:53 PM
Did you use dielectric grease when you changed the plugs and cops?
Old Mar 9, 2011 | 09:13 PM
tang1987's Avatar
Negative on the dielectric grease. Do you think that has anything to do with it?
Old Mar 9, 2011 | 09:42 PM
jethat's Avatar
Yeah it might. The Modular engine with where the plugs are located is very sensitive to moisture. Could be you already fried a coil or 2 from getting them wet..
Old Mar 10, 2011 | 06:48 PM
tang1987's Avatar
i don't know
I am only having this stumble on average about 1 startup a week and then after that everything is fine.
Old Mar 11, 2011 | 09:40 PM
Dielectric grease is REQUIRED - it's not optional.
