View Full Version : Engine
  1. Pinging solved??
  2. Serpentine Belt Question
  3. My truck is a P.O.S.
  4. Spark Plug Boot stuck!
  5. Please help, More performance desired
  6. New to me
  7. superchip?
  8. TFS intake to F150?
  9. Who else makes Air Filters for
  10. Weird rattle noise when starting cold.
  11. Electric Fan
  12. throttle body/ mass air sensor?
  13. Computer troubles? Get one of these.
  14. Another check engine light question!!
  15. 1999 Heads Problem
  16. TERRIBLE Gas Mileage in FX4!!!
  17. Superchip from my v-6 in my v8?
  18. 50,000 maintenance
  19. S&B Filters
  20. Fixed belt squeel under hard throttle.
  21. 30,000 mile service
  22. 1990 diagnostic codes
  23. I want more air
  24. when to do first oil change?
  25. Can I buy O.E. seat covers ?
  26. 2000 F150 Oil Pressure Probelm
  27. Check Engine Light
  28. Decarbonize Engine? Spark Plug Price?
  29. How To Check Plug Wires???
  30. Need tech help with MAF sensor problem.
  31. cruise control
  32. Question about engine removal.
  33. Whistling noise found, can I fix it?
  34. Spark plug replacement
  35. whatcha think
  36. Question about rough idle.
  37. CD2 Engine Cleaner works !!
  38. flowmaster series ????
  39. Holy Horse Power Batman...new mods
  40. Radiator fan noise
  41. Greasy 5.4l engine
  42. Problem with trailer lights.
  43. what is code dtc 5284??
  44. Door Crack
  45. Rear Main Oil Seal Leak
  46. i have a "service engine soon" light...help!
  47. Gas Mileage Update
  48. Does anyone know if you can put MSD ignition on a 2001 f150 5.4?
  49. Black WMS Velocity Tube
  50. New truck, have an issue, could someone assist.
  51. Synthetic Oils?
  52. 300 Straight 6 questions
  53. Check Engine Light
  54. Engine cuts out
  55. ? on Throttle Body
  56. Noises Fixed!!!!
  57. any possible engine problems
  58. cobra vrs. lightning
  59. Amazed, not an ad though
  60. Need help on Clattering Motor
  61. Whose got a surge at startup?
  62. 98 F-150 intermittent NO-START HELP!
  63. i HAVE A HUMMMM AT IDLE AND LOW RPMS?
  64. High mileage V10 and 5.4
  65. Extended Warranty or Not
  66. Where is this coolant coming from??
  67. Code P0401 meaning
  68. HP & torque Question
  69. 5.4L Intake Manifold - Plastic or Alum.
  70. Ever seen a tree hit a Cheby??
  71. Door ajar
  72. California Emissions Package ?
  73. 98 4.6 vs 5.4 Question?
  74. chrome center caps
  75. First Oil Change '02 Screw
  76. HELP! electric fan - engine runs HOT
  77. engine miss or surge problems
  78. need an engine?
  79. CE light, part II. Quick response needed please?
  80. Help with noise???
  81. S.O.S. for the experts !
  82. Confirmed case of K&N air filter screwing up a MAF sensor.
  83. Pulling a 2001 5.4l from F150
  84. Reliability risks
  85. internal engine parts
  86. Code readers?
  87. Need help with Nissan!?!?
  88. Does anyone know all the problems the check engine light indicates?
  89. Fuel cap, check engine light?
  90. Check out this STOCK 500 H.P. DOHC 5.4 that FORD is making!!
  91. Piston Slap??
  92. air injection from turbo city
  93. erratic idle after mods
  94. 4.6L Engine
  95. brands
  96. Should I buy a WMS Velocity Tube since I already have a K&N?
  97. EGR valve insufficient flow
  98. Bad crank pulley
  99. Had to post this
  100. Had plugs replaced and engine light is on!!
  101. Difference between 4.6L V8 in Supercrew vs Supercab?
  102. Fipk
  103. 1997 4.6L dipstick question?
  104. What does FIPK stand for
  105. help!!
  106. 4 valve heads?
  107. Power Pulleys
  108. my truck is missing really really bad and it's pissin me the f@!? off
  109. slugish gas eater ...need help
  110. Got my short block back from the shop today.
  111. Do all XLT's come with remote entry?
  112. Engine Knocking
  113. Exxon Synthetic Oil
  114. MSD Stacker 8 ??
  115. Help! Help! Help! Oh Please Help!
  116. What's that Popping Sound???
  117. OT: How to charge AC system
  118. Need a little help
  119. Possible Purchase Of Used 2000 Lightning
  120. I need a part # for remote oil filter
  121. Electric Fan
  122. 2001 5.4 Blue Smoke
  123. What to buy?
  124. Now I'm confused
  125. 5.4L vs. 5.3L
  126. Question about replacing plugs in 5.4
  127. 4.6 BAD hesitation
  128. Is The dodge/cummins 5.9L I-6 the new King of Diesels?
  129. Strong coolant smell at startup
  130. A tune up this weekend
  131. Time for some bench racing
  132. me and my classmate just got jacked...!!
  133. how often do you guys clean your reusable air filters?
  134. Cheep code reader?
  135. mystery engine
  136. How can I ad factory cruise.
  137. new 270 Hp straight six
  138. axle codes?
  139. Ford Truck- Zero Production
  140. piston slap
  141. 4.6 head gasket leak and exhaust smoke related?
  142. electric fuel pump?.....causing 99 F150 not to start
  143. What's NEW that's comming from Mobil 1????
  144. Spark Plug blown out of cylinder head
  145. salvage yard electric fan kit for 4.6L?
  146. '97+ F150 Ignition Coil Reliability/Replacement
  147. Bottle Fed
  148. 92 5.0 injectors???????
  149. 2 strokes
  150. Fuel Filter Line
  151. Universal Joint?
  152. Underdrive Pulleys
  153. Hey Neal
  154. airforce 1 vs. Mac cold air kit
  155. Volant Air Intake???
  156. p_ferlow--->K&N Air box Mod.
  157. 1992 diagnostic problems...tried everything
  158. buzzing noise from EGR valve solenoid
  159. 5.7L Hemi-magnum
  160. noise coming from engine after body lift
  161. Strange noise from engine?
  162. `99 5.4 surges and misses at 1400 rpm to 1700 rpm, help.
  163. ? regarding air intake systems.
  164. Engine Ping
  165. engine rattle noise , not lifters either hmmmmmm
  166. Found my coolant leak,Check this out!
  167. Fuel Consumption Log
  168. injector clean and larger injectors
  169. Buzzing From Dash
  170. Finally!
  171. If you are looking for horsepower, the answer is on Ebay.
  172. Ordering Amsoil online?
  173. V6 Diesel?
  174. FRAM "SureDrain" (again)
  175. dumb question re: dyno testing
  176. Installing new headers
  177. radiator-transmission cooling question
  178. Oil Filter Location
  179. PINGING!- 87 octane vs. 89 octane
  180. F-150 VS. Dakota V8???
  181. Engine VIN location
  182. speedometer gear and tire size
  183. computer code error P0171 and P0455
  184. My 5.4 is "slapping"!!!
  185. 5.4L Oil Viscosity
  186. Rev limit for 5.4?
  187. Engine oil cooler
  188. performance intake systems
  189. When is it OK to switch to Synthetic Oil
  190. Gen 1 Lightning intake
  191. Time for a performance upgrade, Chip or Headers
  192. 1/8 miles times for 2001/2002 F150 reg. cab 5.4 ??????????????????
  193. My engine oil leak
  194. Problems With My 4.6
  195. Battery Light Comes On
  196. SPark plug and wires suggested? and cutting out
  197. fuel filter change...
  198. Burning oil
  199. whats the best rear end gear ratio for all highway driving.
  200. truck vibration after seafoam help!!!!!!
  201. 5.4L Vs. 6.0L in a pull contest
  202. throttle body and sensor cleaning
  203. Ford admits Quality problem on 5.4's
  204. "The Amazing, Fuel Saving Tornado"...... ?
  205. Cam chain problems?
  206. Air/fuel ratio ??
  207. Oil Pressure Question - Weird Things going on
  208. Break In?
  209. Where\what to get for colored plug wires?
  210. Head Swap
  211. what's the next step...
  212. engine swap
  213. Electric fan conversion
  214. What oil filter(Best)
  215. engine flushing
  216. Head Gasket what to do?
  217. Oil Filters: Hand tightening enough?
  218. Superchips?
  219. Fram SureDRAIN
  220. pvc valve??
  221. Lash Adjusters ?
  222. Is it possible to change engines???
  223. I have a question
  224. Warranty Issue
  225. wanna squeaky clean carbureted fuel system check this trick out!!!!!!!!!
  226. Mobil 1 synthetic
  227. ZMAX, does this stuff REALLY work?
  228. Questions about performance ?????
  229. Lean fuel left/right bank
  230. 1st Tune Up.
  231. anyone running Amsoil bypass filter? please help!
  232. Stumble and smoke at start up
  233. Redline
  234. Fuel Injector Cleaners
  235. camshaft and heads
  236. AirForce 1 Intake, Worth It?
  237. Replace Engine
  238. What rpm at 75 mph?
  239. 4 Questions! :)
  240. pedals uneven
  241. 4.6L V-8 Died Need Advice PLease
  242. 4.6 crate motors
  243. Any ideas on my coolant question below PLEASE!!!
  244. Anybody heard of Golen's Engine Service?
  245. Kinda worried,coolant level question on 2001 5.4
  246. Swapping to PI heads. Serious questions...
  247. Head gasket leaks
  248. Cleaning engines?
  249. Fuel Injector problems ??
  250. TurboCity Intake
