Need Help!
Old Sep 30, 2005 | 08:52 PM
RocknF150's Avatar
Need Help!
I have a 2000 F150 5.4. It runs fine in P or N when you put it in D or R it bogs out and dies. There are no codes. I have replaced AIC, TPS, Cam sensor and the gear selection switch on the tranny. Nothing has worked. I need any advice I can get. Is there maybe a Torque cnverter lockup switch that could be bad. If put it in D and press the gas fast it will drive. It studders at first and then smotths out. If I come to a stop with out putting it in N it will die. Any advice will be greatly appreciated.
Old Sep 30, 2005 | 10:02 PM
98Navi's Avatar
Obviosly (but I will still point out) there is no load on the trans in P and N. I'd say a torque converter is a good place to start
Old Oct 2, 2005 | 07:22 PM
RocknF150's Avatar
torque converter lockup
Is there a switch or a selinoid that locks up the converter? or do you have to just replace the torque converter?
Old Oct 2, 2005 | 08:45 PM
98Navi's Avatar
I don't pretend to know jack about trannies internal workings, and in this case, I don't know jack!
