dead f150
Old Sep 29, 2005 | 03:32 PM
deadf150's Avatar
dead f150
I have a 1994 f150, when I turn the key nothing happens. No grunts, groans or clicks!!! All lights and buzzers work fine. any advice?
Old Sep 29, 2005 | 03:41 PM
Polydorus's Avatar
Battery?
Fuses?
Post your engine type, etc. and wait for the experts to weigh in.
Old Sep 29, 2005 | 03:51 PM
jcc's Avatar
jcc
could be the starter or the starter solonoid coil
Old Sep 29, 2005 | 03:54 PM
tex_n's Avatar
Even without knowing the specifics on your engine, I'd suspect a load test on your battery would prove worthwhile. In my experience, with everything else working, and nothing has been changed, it's the battery. Yours are classic symptoms of a battery. It doesn't take a whole lot of amperage to run buzzers and lights, but it uses a ton of em to turn a starter. If infact, nothing has been done recently to the engine and/or wiring, most autoparts stores will test a battery for you for free. As a side note, loose or corroded battery connections will give the same symptoms. Inspect wires and connections, and then pull your battery and get it tested. Just my 2 cents.....
Old Sep 29, 2005 | 04:36 PM
deadf150's Avatar
deadf150
It has 6 cylinder 4.9L engine. Had no trouble starting before this happened.
Old Sep 29, 2005 | 05:29 PM
wallygator's Avatar
Angry dead f150
have had similar problem w my 97 4.6,check the connection on starter motor at selonoid,4.6has red wire with blk clip on end,it corrodes. Clean and try to increase pressure onto male end of selonoid by tightening clip if you can,I have to do mine 2-3 times a year.Crap design,windstar used to do same thing
Old Sep 30, 2005 | 08:26 AM
cheri/ck's Avatar
Is it a manual transmission? Could be the safety switch on the clutch.
Old Sep 30, 2005 | 08:40 AM
exx's Avatar
exx
I agree, check the battery, get a jump see if it starts then.
Old Sep 30, 2005 | 09:39 AM
jmeyerholtz's Avatar
starter solonoid coil this is what i had happen.
