Advice on changing coolant
I've got a 2001 w/ the 5.4 and 40k miles. I was going to change the coolant this weekend and was looking for advice on draining the block. There appears to be a block drain on the drivers side (hex bolt) and possibly one on the passenger side which is a square head bolt towards the front of the engine. I was told that some engines can get air trapped inside and cause "hot spots" but my Haynes manual says to drain the block. Does anyone know if this is a potential problem on the 5.4 and if so, how to avoid it?
