- 4R70W tranny drain plug pan
- Can you bleed a Clutch?
- Fluid Change
- tranny getting harder to shift
- New Art Carr Transmission
- Tranny Prob or not?
- Shutters and shifts hard, 2nd to 3rd & 3rd to 2nd
- '97 5sp seems to be "whining"???
- trans barely moves in drive ,must manually shift
- B&M Shift Plus
- Squeel from tranny in 1-2 shift
- Yank Torque Converters?
- LE Trans Fluid
- Tansmission Sticker found
- Slight surge when braking in O/D
- Tranny knocking? Torque conv.? Help!
- Tire size and towing
- Do i need to do anything to this Trans
- Shift Kit for 5-speed
- transmission
- Strange shifts on hard acceleration
- Won't shift from Park to Any Other Gear
- Transmission Bang
- '92 F150
- I think I fried my valve body
- what trans can it use
- 5 Speed Auto?
- 4.2L manual trans
- Is there A shift kit?
- Any known problems with 97 Lariat, 4.6L
- Inspection cover left off when new engine installed
- Noise when shifting from reverse to drive......
- slow speed OD slippage.slip yoke TSB a fix?
- Mounting Lights In Front Of Trans. Cooler.
- My Trans Broke!!
- Low trany fluid level from dealer!
- Reverse-to-Drive Tans Slip
- Aftermarket Shifter for 99 4.2??
- gear ratios
- some Q's about driving a manual
- Tranny Fluid Pan Drain Plug
- grinding in 4wd high
- Check your tranny cross bar member!
- 1998 4.2L Manual Tranny Change Interval
- Trans Temp (best Location)
- Any thoughts on More Trans Cooler?
- 95 F-250 4X4 EXT.
- Trann. Fluid
- 2001 5 speed...should I do anything to the tranny?
- 1997 Mercon V vs mercon
- Transfer case whine
- Shutter between 2nd and 3rd under normal Accel
- Transmission Studdering
- What is the best shift kit...please advise..
- 4.6L Manual Transmission Fluid Change
- Shifter anyone?
- Trans temps
- Trans pan
- Mercon V in early E4OD
- part # for Trans Pan Gasket & Filter
- auto popping out of second??
- Resonant noise @ ~1700 rpm reduced after determining TC stall speed.
- Need info on 5spd tranny
- High-stall torque converter good investment for acceleration?
- 2001 SuperCrew + Bad Transmission
- Draining The Torque Converter
- Manual Transmission Drainage
- Shifting Hard
- overdrive on/off
- Mobil 1 Synthetic ATF in 5sp?
- Chattering Tranny
- transmission popping
- Grinding Transmission
- Leaking differential, worry or not?
- TSB 98-8-8
- What's your torque converter's stall speed?
- SLIP YOKE TSB... WHERE TO FIND???
- TRANSMISSION
- OD Controll fuse keep blowing
- What's this plastic thingie rolling around in my trans pan?
- 5 spd whine on steep grades
- Speedo correction?
- auto. trans. identification
- Reverse light switch on SuperDuty 5 sp tranny
- 4.6 supercharger and transmission?
- tranny slippage
- Rand, the "slipping" feeling . . .
- shuttering trans
- Just another clunk (P to R back to P
- I have a (dumb) question about how the OD works.
- 30000 mile tranny change flush or pan drop
- Kansas City v. Norfolk
- Tran Fluid Change
- New Tranny Fluid or New Timing Chip?
- Coasting in Neutral with Manual Transmission
- Shift Kit, Torque converter, ect... What would be best??
- 1999 F150 AUTO TRANS HIGH REV.
- 2001 4R100 Failures - Stop Build
- Shift Kits and Warranty
- TRANSMISSION RELIABILITY
- Slush Box No More!!!
- Need to know what kind of tranny I have?
- "Slipping" feeling in tranny?
- Clutch Resevoire (How Full?)
- cruse control down shifting
- Transmission "lurching" during downshift
- Trans goin out??
- Trany. Shift Kit
- Drain Tube?
- 4 Wheel Low light not working?
- Intermittent delayed shifting out of 1st
- need tranny for '88 F150 4spd w/OD
- ELECTRONIC SHIFT ON FLY OR STICK
- Roaring from 0-15 mph
- What tranny fluid Should I use in my 5-speed???
- Troubled F 150 owner-please help
- TRANS & COMPUTER... HOW DO THEY WORK TOGETHER?
- 35-40 mph vibration
- transmission vent?
- Limp mode E4OD
- Transmission Failure
- Using the overdrive button...
- Routine Trans Service: Advice?
- Leaking Trans Fluid
- Tranny won't go into park.....
- How often does changing the tranny fluid fix problems?
- mlp sensor
- Transmission # 2 And a Rear End!
- Tranny Broke On Dyno!
- MY TRUCK IS SICK -E4OD-4.9L
- transmission
- Tranny about to go??
- Does the TC have a clutch?
- Trim Ring on Gearshift Lever keeps Coming off
- Outside Temperature Gauge used for Measuring Transmission Temperature
- Clutch quit this morning
- auto transmission loss in 3rd gear
- metal shavings
- IS Mobil 1 ATF rated 'Mercon V'?????
- Just installed Amsoil synthetic in tranny and transfer case, 97 manual
- Transmission slip, 3rd gear
- the street runner and this weekend trip
- Another Question on Tranny Fluid Changes
- Please Help-Tranny Problem
- Tranny Cracked
- Torque converter problems
- Anyone else Tranny Squeekin?
- grinding
- Transmission temperature
- To Eveolve or Stgnate?
- Trans. Flush No Mercon 5
- Trans Fluid Change vs. Flush
- 3.08 to a 4.10?
- Synthetic Tranny Fluid??
- Must be a problem with JET trans kit install, shifting too hard?
- TSB 99 14 sticker on 2001 auto SuperCrew
- Bigger Tires=Different Gear ratio?
- Brand of Mercon V
- Transmission slipping on 4R70W
- Any one familiar with the JET Electrical and Mechanical Shift Improvement Kit (4x4)?
- M5OD No 5th or reverse
- What size rear end?
- TRANNY FLUID
- Hubs not locking
- B&M Trany Fluid?
- OD
- new member needs trans help on 1999
- Make your own Gauge Pod
- Manual Transmission Warranty?
- Manual Trans Rough Shift To 2nd
- B&M Shift Kit, Same As ****ft Plus??
- Towing in OD
- Rear diff, going to switch gears, need help
- Overdrive light blinking????
- 97 vs 00 Manual Trans
- Someone Explain Gear Ratio Pro's and Cons
- Magnet in Tranny pan?
- Changing tranny fluid
- Transmission Troubles
- O/D Disabled Automatically
- Rough Shift to Second Gear
- B&M Shift Improvement Kit
- sick tranny?
- vibration
- No REVERSE when engine is hot
- How to determine axle ratio on used F150
- Tranny rolls back in drive on inclines
- Why does my 83 bronco shift better then my 98 f250?
- Hard shift into 2nd
- C4 transmission died suddenly??
- Advice on B&M Shiftplus please?
- "Chirping" sound in 2nd gear 4R70W
- Transmission gear ratios?
- Redline Oil
- Torque Conveter Drain Plug Torque?
- Transmission ID?
- Engine braking
- B&M Shift Kit Installed
- Hard upshifts with E40D
- E40D Oil Change & Filter How Much?
- help re. driving in O.D.???
- 4R70W Pressure Plug Thread Size??
- Where can I buy trans. temp guage?
- help re. transmission type for a 1999 f150????
- 5 spd manual grinds between 1 and 2nd gear?
- 4x4 Shifting problems???
- Can you swap in a heavy duty transmission?
- Transmission hangs in 2nd gear
- 3.08 to 3.55 swap
- Powerflush affecting mileage?
- Tranny Cooler Installation
- 4R70W and Temp Gauge
- tranny swapping
- Very Hard Shifing from drive to reverse
- normal tranny temp
- Clutch problem
- Say good-bye to manual transmissions?
- 4r70w or e4od
- anyone else got THIS problem???
- I JUST DON'T GET IT........
- Shiftplus long term use
- OVERDRIVE RATIO
- 3.08 to 3.55
- Manual tranny
- Is it worth it to replace auto trans fluid with synth?
- 4 X 4 F - up
- Rear Axle Ratios
- Trans Temp Gauge Install
- Auto Trans Temperature
- Gear selector adjustment?
- Tranny Weight
- tranny shutter
- Firmer shifts for auto tranny
- fluid leaking from differential
- reset shift points by computer...how-to???
- banks transcommand / ottomind
- trans code U....?????
- Slight "shudder" at take off.
- Underbody rust on new F150...
- High Stall Speed Torque Convertors
- Bang Shifting E4OD
- 5speed short throw kit
- XL 4X2 5-speeds can have a tach
- shifting suggestions
- M50D
- Was the the 4R70W designed for a '71 Pinto
- Blown or Blown Tranny
