Popping out of 5th gear
Old Nov 4, 2004 | 01:23 PM
jason2lightfoot's Avatar
I am able to shift into 5th gear, but as soon as I try to accelerate.... it pops out o gear. i can stay in 5th gear as long as I don't try to accelerate to hard. I guess this means that the gear is barely engaging. I know very little about transmissions....in fact my uncle replaced the shift fork that engages 1st and 2nd gear. The fork was worn thin so that it was not grabing the gear to slide it into place. Every since then...as far as i can remember..I have had the 5th gear problem of popping out of gear. I am not sure if something could have been adjusted by changing out that fork that would through the 5th gear alignment off or not. I need help. and comments or suggestions would be greatly appreciated.
Old Nov 4, 2004 | 07:20 PM
piperc's Avatar
Account Suspended For Violation of Terms of Service
the fifth gear synchronizer ring is worn
Old Nov 6, 2004 | 01:43 PM
ThunderCat's Avatar
I recently had to have the transmission rebuilt in my 2000 F150 Supercrew. I'm still having issues with it though. It's holding back before it changes into the next gear and somethimes the RPMs will go up excessively while doing so. I have a 25,000 mile warranty on the rebuild. Should I take it back to get reserviced? I had the transmission replaced initially because it kept slipping out of overdrive and I would have to put it into Drive 2 to drive it. It wasn't pushing into the gears hard like that before. What could be the problem? Anyone know?
Old Nov 6, 2004 | 02:11 PM
piperc's Avatar
definately. take it back. if it's popping out of 5th gear after a rebuild, it should be fixed. what do you mean "holding back, then reving excessivley"?
Old Nov 7, 2004 | 10:27 PM
ThunderCat's Avatar
It's not popping out of 5th gear anymore since I took it back for that. But it's still not right. What I mean by "holding back" is that say, when it's it 2nd gear it feels like it's just fighting with me to go into 3rd gear and when it does it jerks really hard. The RPMs go up excessively while it's in the change.
Old Nov 7, 2004 | 10:59 PM
piperc's Avatar
what do you mean rev up while changing into 3rd?
is this with your foot off the accel pedal? ask the shop that rebuilt it for you
Old Nov 8, 2004 | 09:29 PM
ThunderCat's Avatar
It's while I am accelerating. It just seems like it's killing it to go into another gear.
