Overdrive light flashing
I own a 1998 F250 4.6 2 wheel drive with a 127k miles. Just the other day after driving it about 5 miles the overdrive light started flashing and would not shut off until I shut the vehicle off and restarted it. Tranny fluid level is fine, any clues on what it maybe.
Had the truck scanned
My father has a scanner and no trouble codes were found. I noticed it will only flash about 5 minutes after driving. Shut the car off then back on, light is gone until 5 minutes later. The truck has been shifting a little ruff since this started.
They said nothing, and because of the speed that they were willing to do it, I just said go. It was almost out of warranty. I tow a trailer, but it is only about 6000 lbs. Truck was stolen & recovered a few thousand miles earlier, so that may have had something to do with it. 35K for a tranny seems way early though.
Driving a '97 that just turned 200,000 miles today. A great runner that looks great too.
This evening while driving home, approx 65 mph, the OD light started flashing. The OD switch was working fine and there were no other noticeable problems. When I turned off the ignition and restarted it the light stayed off.
I've seen several different treads that have covered this and several have mentioned the light that stops after restarting.
Can anyone tell me what they found out, as far as what the problem was?
Any help would be greatly appreciated.
Doug
Doug
Re: Just happened in mine
Doug
Doug
From what I've read on this message board and others (ahem) it seems like it could be anything from a simple repair to a need for a full rebuild. AAMCO (I know they often get a bad rap) said the repair on my F150 would be anywhere from $1800 - $3000. I'm glad it's a dealer expense on mine. Hopefully yours is something simple and inexpensive!
