Can't anyone help with my tranny question pleassseee !!!
on
You have not asked a question. If you want some one to confirm your statement then try this forum.
http://www.j-body.org/forums/read.ph...=13609&t=13609
Regards
JMC
Regards
JMC
on
If your tranny doesn't have a dipstick it should have a large drain plug in the pan with a check plug which is located in the center of the drain plug. Holding the drain plug with the proper size wrench so as not to loosen the drain plug, proceed to remove the check plug with the proper size Allen wrench. If the transmission is operating at the proper fluid capacity the transmission fluid should just trickle over the stem and out through the center of the drain plug. In the event that no fluid is released, this is a good indication of low or improper fluid levels.
Installation of new fluid: To install new fluid in the transmission, locate the (Fill Plug) in the extension housing of the transmission, the plug is identified by instructions for transmission fluid application.
JMC
JMC
