what transmission?
Old Sep 14, 2004 | 11:48 AM
97svt cobra's Avatar
what transmission?
I have a '97 f150 4.6 4x4 auto, just wondering if there is any way to determine which trans it might be? Might there be anything stamped on the housing?
Old Sep 14, 2004 | 11:49 AM
bigtruck311's Avatar
check on the door jam there should be a trans code there on the drivers side
Old Sep 14, 2004 | 04:19 PM
thanks
Old Sep 14, 2004 | 05:38 PM
brahmus's Avatar
u=4R70W
E=4R100
I'm willing to bet you have the 4r70w
Old Sep 15, 2004 | 12:37 PM
Yep, its a "U" code. I have the old 4.6 out of the truck and i'm installing a 2002 5.4 w/ lightning SC'er , so will the stock TQ converter i have work (withstand) with this motor or should I upgrade?
Old Sep 15, 2004 | 01:10 PM
brahmus's Avatar
depends how much you juice up the "L" motor, see sig and gallery. I got an art carr converter $$ but it is holding up so far. I also upgraded the tranny, race build, artcarr clutch pack (extra clutches plates), hardened intermediate shaft and FTVB!
Old Sep 15, 2004 | 01:50 PM
yeah, I was going to leave the motor pretty much in its stock trim. Do you know if the 5.4 and the 4.6 w/ the 4r70w use the same converter?
Old Sep 15, 2004 | 01:55 PM
brahmus's Avatar
not 100% certain but if you go into the supercharger/turbo forum find "iron horse" he is doing the swap also from a 4.6 and has been doing some converter research. he will be glad to help you and probably has the answer you are looking for. at the minimum i'd put a FTVB then run the tranny till it blows then get a race build and upgrade the above.
Old Sep 15, 2004 | 02:15 PM
sounds good, thanks for your help
