Question for dirtydog
Old Oct 29, 2004 | 05:47 AM
BlueOvalFitter's Avatar
Question Question for dirtydog
I see you are a 4R70W guru.What are the signs and symptoms of the 1-2 hard shift,and is it related to the 2-1 downshift? I service my own trans. and use Motorcraft MerconV exclusively,every 15-20k miles,along with Motorcraft filters.
Old Oct 29, 2004 | 09:09 AM
dirtyd0g's Avatar
I'm not really sure I understand the question. Signs and symptoms of a hard shift? Hard shift is the symptom of broken springs,but then sometimes the shifts become soft. Not all of them act the same when the spring breaks in the 1-2 accumulator. I'm not really a guru I build torque converters and work in a transmission shop. Yes the 1-2 is related to the 2-1 they both use that accumulator to control the shift feel.
Alan
Old Oct 29, 2004 | 02:23 PM
My 1-2 shift is ok.The 2-1 usually thumps,thunks,knocks,or whatever you want to call it.And,you can hear the transmission whine in each gear on the 2-1 downshift. Is this a concern or am I just being paranoid?
Old Oct 29, 2004 | 06:23 PM
dirtyd0g's Avatar
Are you meaning 2-1 under throttle or 2-1 slowing down? Have you checked the u-joints and rearend? Sounds like a sloppy rearend to me if it is making a thunk. How are the mounts?
Alan
Old Oct 29, 2004 | 06:37 PM
I'm referring to the 2-1 slowing down.That does make sense about the u-joints tho.I also here a similar noise when I put the truck in reverse.Stands to reason it would make that noise then.But,what about the tranny whining? And I know its not the rear end.Maybe i'm just being too paranoid thinking the whining is something wrong.
Old Oct 29, 2004 | 06:53 PM
dirtyd0g's Avatar
Got me thinking the ring and pinion are about shot.
Old Oct 29, 2004 | 07:15 PM
How do you gather this info from what I have provided? The tranny is what is whining,not the rear end.And,as you stated,the u-joints might be bad.This makes sense.In all the other hype I was caught up in ide forgotten about the u-joints.As you know,99% of the time you are driving in one direction,putting excess load and stress on the u-joints.In time they will start to get loose.Putting it in reverse changes that direction,thus causing that forward slack to appear,going the other direction.
Anyway,I bought 12 quarts of Motorcraft MerconV and a filter.I'm gonna look at my 1-2 spring while i'm in there.Is it true there is a pink or white spring to choose from?Any tips on how to compress the spring to re-install the snap ring? I was thinking bottle jack.
Old Oct 29, 2004 | 07:25 PM
dirtyd0g's Avatar
Pink/white was factory on alot of 4r70w's They seem to be the ones that break. Ford has a new setup I know one of them is brown. Tell the dealership you want springs for a 2003 and use them. Are you sure the whining is coming from the transmission?
Alan
Old Oct 29, 2004 | 07:39 PM
piperc's Avatar
Account Suspended For Violation of Terms of Service
hey, next week when i get the parts, i'm going to start on the same project. i know i got the updated accumulator, but do i need a updated spring? thanks. i plan to drain the torque converter and fill up with mercon V. thanks
Old Oct 29, 2004 | 07:49 PM
dirtyd0g's Avatar
You don't "need" the springs they are just a little firmer shifting than the other setup.
Alan
Old Nov 1, 2004 | 09:31 AM
Darrin Burch's Avatar
I use my thumb to compress the springs to get the snap ring back in there. Ford sells a tool, but it is more work than using my thumb and costs a whole lot more.
