- creamy stuff on oil cap
- front gasket coolant leak & Ford Co?
- Hessitaing or Jerking
- Front Cover Gaskets- Beware when buying kits!
- Calling all 4.2 v6ers (PLEASE HELP!)
- Lemon Update, My truck has MORE issues!
- V6 power
- Tornado intake part? "As Seen on TV"
- Race stories anyone?
- power lock problem
- Worn Wires
- Argh! Bent Rods!
- Smokin' tail pipe
- Replacing 4.2 engine
- Shift points and red line
- Resetting The Computer
- Registration is now open for the V6 Ford Challenge
- Traded UP Moving Out
- Terrible grating noise when starting up
- Synthetic oil
- need a quick measurement...
- 97 Failed Intake Gaskets- PICS!
- Extended Warranties
- Gasket Going Bad Warning Signs?
- Valve train ticking / rattling?
- V-6 exhaust leak when cold?
- coolant leak
- pressure testing
- water in oil filler
- more problems with my truck....
- O2 sensors
- Spark plugs.....
- Check engine light
- Rattling noise...
- Gasket Repair for AJ
- v6 coolant
- My Gasket Story
- Missing in 2nd gear
- My Truck Is A Lemon!!!!!!!!!!!!!!!!!!!!!!!!!!
- 97 F150 4.2L won't start....help?
- Electric Superchager
- Ignition upgrade question
- Switching from dino oil to synthetic
- 2004= not more 4.2?
- Performance Intake Chip = 20hp ???
- 97 f150 W/surging idle --IDEAS--?
- Need more power - 4x4 / 4.2-
- O2 engine code
- Port & Polish How TO???
- 1998 4.2 intake gasket question
- rims/tires
- 97 4.2 - hissing on shutdown
- gas mileage decreasing?
- Please Help! - 97 4.2 - hard starting
- Hate To Ask, but 97 Gasket Issue Questions
- Got Nut?
- Engine noise at start
- thanks senior members
- Ravin on a 4.2 experienced only please
- need poorman's intake instructions
- Got My New Intake Today!!!
- Message Board
- limited slip conversion
- 98 4.2 engine code
- Anti Freeze leak-Head Gasket
- v-6
- newbie --- Gas mileage
- Truck Appreciation
- wow
- 2001 Exhaust Leak, please help
- Belltech 2" drop shackles
- 2 Different Spark Plugs in Engine
- Broke My Airaid
- When do you shift, when you are in a hurry?
- 2002 v6
- Id like to see a Chevy V-6 tow that!
- How to paint Calipers?
- 4.2L Mods Need Some Help
- valve sizes
- i dont get it.
- Another poor 97 4.2 Owner
- Back Guys and gals!
- v6 with low oil pressure
- Electric Fans/ Pulleys
- 97 coolant leaks /
- check engine
- fuel prob
- ((ABS)) Warning Light
- V-6 under 70K miles
- axle leak? or too full
- Better 4.2 Performance
- wanting advice
- just curious
- '97 4.2L Bent Rod
- Hate the 4.2 v6
- Took my throttle-body off to clean...
- Tail light mod
- Towing With my V-6 this past LONG weekend/LS 3.55/Radiator
- no floor heat,comes out defroster when set to floor.Ever happen to you?
- thank you all
- Aftermarket AC!!
- V6 Ford Challenge II race date has been set
- I got no TACH
- Where has Talleywacker gone?
- Newby w/ 95 F150 questions????
- what can I do?
- Strange cold start
- V8 intake on a V6?
- Lawyers and the 4.2
- Sound files of V6 Exhaust?
- Oil Filters - Exposed
- man if i had only known...
- Raced an Explore Sport Today
- jba headers
- Louder 4.2
- Rough Idle in Gear?
- NOS In a V-6
- Who has a 2002 4.2 with ASP pulleys?
- Best intake?
- well.. it happenned to my 4.2 as well
- damn price..
- Whats the best place to start with Mods?
- 97, 4.2 knocking
- For those with a chip...
- Any Camshafts for v-6??
- >>>More POWER!!!<<<
- V-6 Ehaust
- New cats, again?
- Mods for better mileage
- Moaning sound from engine when starting in morning
- body lift and air intake
- Drag Strip
- Burnouts Today/4.2L Potential
- MSD ignition, tried to search couldn't find
- K@N Filter
- Towing with my V-6
- $1,000 for mods...what to get?
- Hiccups
- Great run with a V8
- Is this true?
- Major Hesitation at high speeds
- What can stop pinging?
- sepintine belt replacement V 6
- Does the 4.2l have 4-bolt main bearings?
- OBD2 code P0445
- response
- instant throttle response
- V-6 max speed
- 4.2L Vortech kits...
- Replacement Carpet
- 1997 4.2L Ford Contact Info!!!
- 4.2 Spark Plug Fouling
- Wheezing sound????
- throttle body
- Belt Maintenace
- Thanks Whitestx
- Spark plug change out and truck will not start.
- tires for stock rims
- V6 Ford Challenge II info
- Expanding Recall 99B29 (1997 4.2L)
- '97 4.2L Problems
- NEW POST Re: MSD Wires (4.2)
- Domo...... 4.10's and lift
- rough running 97 f-150 (idle c.v. ?)
- oxygen sencer ? 97 4.2 v6
- P1120 TPS Out Of Range Low
- MSD Plug Wires (4.2)
- Just finished......
- any relation
- Badge Removal
- speedometer goes from 0-100 mph at start-up!
- all 4.2s!
- MAF Sensor
- here I am again, intake question
- Rear End Question...
- Spark plug gap
- Kicked in the jewels
- foglights
- E brakes
- Quick Question
- wow, what a deal..
- Fog Lights
- F150 V6 vs 7.3L international F250 ????? Take a Look ?????
- "Free" Fuel Filter
- 97 4.2 v-6 recall info?
- Hesitation/Missing after spark plug change
- New mods for my truck!
- To All......
- you guys want long tube headders!!?
- Riloatm----------->
- Is a Tach possible??
- 4.2L power pulleys?
- 4.2 Horror stories
- Check Engine/Code P1538
- S-Coupe charger?
- Knock Sensor
- swap v6 to v8
- Happy Anniversary
- Turbos
- Superchargers, Turbos, & Nitrous
- Redline
- 4.2 V-6 Red Line
- Fordchip....wow...............
- Tools
- 97 4.2L w/ac thermostat location??
- 2000 4.2l
- Timing cover gasket
- Gears And Rpms....
- code
- Tall Tom!!!!
- Are Power Pulleys Any Good?
- Is this possible
- v-6 to v-8 swap...
- new pic's
- start up noise
- Kind of hazy antifreeze
- V-6 (V-sucks)
- Coil Packs
- Rocker Arms
- TSB's
- Proper way to tighten lug nuts??
- 0-60
- Exhaust Questions
- couple more questions for the V6
- How to tell if my motor has been changed
- single solenoid click when starting in damp cool weather
- what's up all?!
- 2003 4.2V6 K& N Filter
- Has Anyone Ever ...
- Is this the right MAC system? & quest. bout intake or chip?
- where to buy billet gas cap and accessories
- New Ride in the driveway
- Few Questions...Superchip, Air Intake, Exhaust, Supercharger
- Underpowered?
- What exhaust sounds the best??
- Mods
- Wheel bearings and alignment ?
- Best Mod for Under $50.00, Anyone????
- Feels Like Being Tapped From Behind
- More Power - differant ways
- 4.2 lt v6 97 knock and lock 87,000
- 4.2 lt v6 knocking or locked up problem..solution
- Water Pump on 97
- amsoil
- Which FIPK claims to make the most h/p on the 4.2?
- FastGaF150???
- Msd Ignition
- truck starts ruff
- Has any done this
- void waranty???
