better MPG
better MPG
Hey all,
i was just wondering if you guys knew of anything that I could do to the engine in order to squeeze acouple more MPG's out of my truck...I owe too much so I am stuck with keeping the truck for now
thx
thx
Originally Posted by genshi800
Throw a lil whiskey in the tank..
No dont, bad idea... Forget I mentio.... Actually, let me go try it, thats a damned interesting thought!
Clean your MAF with CRC MAF cleaner [read the instructions first]. Change 02 sensors if they have not been changed in 60000 miles. New PCV if it has not been changed [check the hose for holes on PCV]. Clean EGR ports in the throttle body. Check tire pressure. Watch your right foot! Naturally plugs and wires. Oh yea, make sure air filter is clean.
remove foot from gas pedal.
ok maybe not as funny as the smiley makes it.
CAI, programmer, electric fans, and if your really worried about it go to 3.08 gears if they were not stock.
and with the above you should be good for better mpg.
ok maybe not as funny as the smiley makes it.CAI, programmer, electric fans, and if your really worried about it go to 3.08 gears if they were not stock.
ive got a k&n drop in filter and i have noticed better gas mileage..the difference when you accelerate is so much better....or if you want to spend more money get an air intake system
All I've done so far is a K&N dropin and a low restriction muffler (which was half the price of a stock muffler). I'm planning on switching all lubes to Amsoil synthetics. I'm looking at spark plug and wire options (in another thread) because I've got 62k miles on the originals. I can't justify the expense of an intake and/or a tuner/chip, the price of these things will buy a lot of gas. I'm the type of person that replaces parts with upgraded parts when it's time to change them anyway. Keep your tire pressures up.
I wonder if a bug deflector would help or hurt drag - or have no effect? I'm thinking about one of those just to keep the windshield cleaner.
Remove any excess weight you are carrying around.Keep the tires inflated properly.Don't accelerate quickly from stops.Slow down when driving on the interstate.Avoid excessive idling.Keep the engine tuned up correctly.Fill up when the temperature outside is the lowest.
Originally Posted by 306stang
your complaining about mpg and you have a v-6 . . .?
WOW
WOW
