My New Truck
Old Oct 10, 2006 | 04:45 PM
Bad@$$04Ford's Avatar
My New Truck
Ok,
here it is, i just bought me an 04 f150 v6 4.2l, 5spd. i want to know if there is any major or minor common problems with these engines, trucks or what. mine only has 56,600 miles on it and nice clean truck. but lay it on me hopefully there wont be too much bad news if any.
thanks, Tim AKA BUBBA
Old Oct 10, 2006 | 05:25 PM
Peacemaker's Avatar
Congrats. No problems that I've heard of.
Change your oil & filter every 5k miles if you use the recommended 5W-20 Motorcraft synthetic-blend. Grease the steering componants every oil change, change your "tranny fluid" every 30k miles (uses 3.75 qts of Mercon ATF), keep an eye on your coolant and gear oil. You know the drill.
Old Oct 10, 2006 | 06:25 PM
i appreciate the tips and like i said i was told(when i worked at this oil change place) that manuals do not take fluid, so in knowing that they do NOW, where do i put the fluid in at.
Old Oct 10, 2006 | 09:20 PM
MXrob26's Avatar
i have a 04' heritage. is yours new or old body style? mine has been a great truck so far and it only has 34000miles.
Old Oct 10, 2006 | 10:34 PM
Peacemaker's Avatar
Well, my 2001 M5OD tranny has a drain and a fill hole on the driver's side of the tranny. I don't know about the 04+ F-150's with the manual. You might check your owner's manual to make sure how much and what kind of tranny fluid to use, just to make sure.
If Ford is using the same M5OD transmissions on the 04+ V6 models, it problably uses Mercon ATF like the Heritage bodystyle. I'm just guessing, but the best thing to do is check your owner's manual.
Also, you could ask Quintin over in the 04' forum about it. I do believe he's a Ford tech, and he should be able to tell you anything you want to know about your truck.
Good luck with your new F-150!
Old Oct 11, 2006 | 04:09 PM
My truck is the heritage body style, and so far i love my truck.im a little lonely without the 4x4 but thats what my play to out back is for.
Old Oct 11, 2006 | 04:17 PM
Jamzwayne has a V6 Heritage as well. Good luck with it.
Old Oct 14, 2006 | 11:17 PM
Wild Bill's Avatar
I have 13,000 miles on mine. Its also a 4.2L 5-speed. Only issue so far was a leaky differential seal. Took it to the local Ford dealership and they re-sealed it under warranty.
Old Oct 15, 2006 | 04:15 PM
Montana Bronco's Avatar
2004 Heritage 4x4 4.2 V6 5-speed manual
No problems at all.
22,000 miles.
These are good trucks. They are at the end of body style and the engine and transmissions are mature. All of the bugs have been sorted out and solved by Ford.
Congratulations on your new truck. It will last you a long time.
