? on code
Originally Posted by Big 4x4s
just wondering if any of you guys have a had code number 0174 dont know what it is or how to fix it
Click on the word "Search", enter the fault code "P0174" as your SEARCH argument and submit it.
Originally Posted by pablrodriguez
i have the same problem but both banks are lean. anyone else fix this problem. what was it?
Click on the SEARCH button and enter the keyword "P0171 P0174" as your SEARch argument.
Steve
There's a guy on ford f150 .net that has the same codes. He found that his vacuum lines over by the pcv that split into a Y were cracked, an the rubber elbow that's under the throttle body had worn a hole in it. He replaced the vacuum lines and the rubber hose, and his lean codes are gone now. It's the first or second thread in the v6 forum over there. Check it out.
