'05 Dying at stops & while driving
Old Apr 21, 2007 | 08:28 PM
sherriinky's Avatar
I'm hoping that someone here can help me out because it sure seems that my dealer is completely useless!!!
I have an '05 screw with 30K miles. Off and on for the last 6 months, occasionally when coming to a stop, my truck will die suddenly but will also start right back up. Now, for the last two weeks, I don't want to even drive it, NOW it will just completely stop WHILE I'm driving down the road. I just had my 30K maintence (oil chg, oil filter, fuel filter, etc.) Dealer says they can't "duplicate" the problem. Not sure how they can't , all they gotta do is drive the damn thing! Not to mention when I had my oil change, it had used up all the damn oil...seems i'm being told 1 quart per 900-1200 miles is now "normal"....wow!
They had my truck for 10 days, picked it up today and it happened on my way home. I'm in a rental and they are coming to back to get my truck on Monday.......I'm hopeful someone can give me some ideas to give to them!!!!!! HELP!!!
Old Apr 22, 2007 | 01:26 PM
jhitti's Avatar
my girlfriends car was doin the same thing with shutting off and it was a vacuum leak. i dont no if that helps.
Old Apr 22, 2007 | 06:35 PM
Peacemaker's Avatar
That sucks man. All I can say is try a different dealer. You might find one that's actually competent. Also, that's not normal for your truck to use that much oil. My 01' 4.2L hasn't hardly used a drop between oil changes unless I drive it hard in the Summer heat. I'd tell them that's BS, and call the BBB.
Old Apr 29, 2007 | 01:22 AM
davisote's Avatar
You must have a dirty throttle body and air regulator valve, you should buy a throttle body cleaner spray follow the procedure described in the can. I had the same problem with my truck. I just clean the throttle and air flow regulator and the problem was solved.
Old Apr 29, 2007 | 03:09 PM
T-roy's Avatar
I had one of my cars do that to me and it was the O2 sensor. Whenever I would stop or let off the gas to coast it would shut down on me, but it would always turn back on.
